Gauges Wireing HELP!!
Old Apr 2, 2009 | 07:57 PM
Timmy2500's Avatar
Car: '86 Z28
Engine: 5.0
Transmission: m39
when I bought the car it had a painless wireing kit put in but whoever wired it obviously did not know what was going on so after rewireing the thing again I have an issue with the gauges the right half of the instrument cluster backlighting is dead and tach, oil and volts work untill I turn on the headlights then the tach, oil, and volts go dead?? anyone have the instrument cluster pinning for an 86?? any help is appreaciated
Old Apr 2, 2009 | 11:06 PM
Timmy2500's Avatar
Car: '86 Z28
Engine: 5.0
Transmission: m39
Re: Gauges Wireing HELP!!
Also to clairify when headlights come on and gauges go dead they drop to min reading, excpt the tach it freezes where it is
Old Apr 3, 2009 | 05:27 PM
Timmy2500's Avatar
Car: '86 Z28
Engine: 5.0
Transmission: m39
Anyone?
Old Apr 3, 2009 | 06:35 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Almost sounds like a short. I would recheck the illumination and ground wiresfor the cluster. Are you using any of the factry wiring or is it all through painless?
Old Apr 3, 2009 | 07:40 PM
Timmy2500's Avatar
Car: '86 Z28
Engine: 5.0
Transmission: m39
everything is painless except wires comming down from steering whell horn, turn sig etc.
Old Apr 3, 2009 | 09:36 PM
groundrat's Avatar
Car: 91Z28
I would look at your wiring for those gauges. you may have something backwards.
Old Apr 3, 2009 | 10:39 PM
Timmy2500's Avatar
Car: '86 Z28
Engine: 5.0
Transmission: m39
just came went thru them again (4th time) everything one by one everything appears to be where its suppost to something still not right.... Its probally right in front of me I just can see it
Old Apr 4, 2009 | 08:07 PM
Timmy2500's Avatar
Car: '86 Z28
Engine: 5.0
Transmission: m39
Found it bad spot on the printed circut
Fixed it Everything works
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
