gauge cluster help please
Old Apr 15, 2009 | 02:07 PM
Guest
Guest
Posts: n/a
i just bought a new cluster for my 87 iroc-z 350 TPI 145mph speedo. the new one came from a 305 TBI when i hook it up the tach goes way above normal?? is their something i can change on the tach to make it work right? my original speedo and tach look the same but the new tach hits red a 5000 rpms and my original tach hit red at 5500 rpms? i hope its something simple. also when i put the key in and start it the buzzer never stops??
Old Apr 15, 2009 | 02:49 PM
Guest
Guest
Posts: n/a
Re: gauge cluster help please
bump please
Old Apr 15, 2009 | 03:09 PM
Guest
Guest
Posts: n/a
i noticed a yellow box on back of clusters. can i swap this and maybe fix my tach??
Old Apr 15, 2009 | 03:29 PM
Guest
Guest
Posts: n/a
any ideas?
Old Apr 15, 2009 | 04:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
any ideas?
If your original cluster functioned as designed, I'd swap the new speedo head and tach into it. I always recommend the above to avoid electrical gremlins of the sort you mention.
JamesC
Old Apr 15, 2009 | 04:31 PM
Guest
Guest
Posts: n/a
well i fixed it i just took my old tach out and put it in the new cluster works great now!! i unhooked the black box that makes that ring sound. so no more sound either!! will it hurt anything having the black box unhooked??
Old Apr 15, 2009 | 04:37 PM
JamesC's Avatar
Great? Not if you still have a problem. Disabling the chime won't hurt, but knowing the system isn't working correctly would drive this **** old fart to distraction.
JamesC
Old Apr 15, 2009 | 04:45 PM
Guest
Guest
Posts: n/a
i see. would my brake light being on cause the chime to go off? cause my back brakes are blocked off right now which i know is not safe.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
