Having problem finding horn relay
Old Apr 18, 2009 | 08:37 PM
Hardtime's Avatar
Car: 89 formula firebird
Engine: 5.0
Transmission: 5 speed
Axle/Gears: stock
I have a 89 formula and the horn came one while i was driving and stayed on untill i unpluged it. Then the battery started going dead so i though horn relay, but i cant find it no where. Does anyone know where i can find it.
Thanks, Hardtime
Old Apr 18, 2009 | 09:56 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Having problem finding horn relay
Thanks, Hardtime
Take a look at this thread:https://www.thirdgen.org/forums/elec...dang-horn.html
Old Apr 18, 2009 | 11:01 PM
Hardtime's Avatar
Engine: 5.0
Axle/Gears: stock
Thanks so much, Ill check it out .
Old Apr 20, 2009 | 05:51 PM
Hardtime's Avatar
Engine: 5.0
Axle/Gears: stock
Thanks got new horn relay in but horn is still staying on.
Old Apr 20, 2009 | 05:52 PM
jv9999's Avatar
Engine: 5.7L/350
Time to look at the steering wheel.
Old Apr 20, 2009 | 05:57 PM
Hardtime's Avatar
Engine: 5.0
Axle/Gears: stock
The horn buttons seam to work fine. I guess there could be a broke wire in there.
Old Apr 20, 2009 | 07:26 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
unhook your horn buttons see if it still stays on if so usually that lil yellow wire that connexts the wheel to the column rubs bare some times makin contact
Glowsock
Jul 24, 2025 03:15 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
