VSS wireing
Old Apr 23, 2009 | 04:30 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
VSS wireing
just to confirm.
i have the wireing and everything up to under the hood, but have some things cut out when i switched to carb and i think i cut out the VSS wireing. what color wires were they? Purple and Yellow? or black and yellow? (the ones that connect directly to the sensor on the transmission)
secondly, is it in the driver side wireing harness?
Old Apr 23, 2009 | 11:04 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: VSS wireing
On my 87 GTA - purple and yellow. Also, it did go through the driverside (C100?) connector.
Old Apr 24, 2009 | 07:39 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: VSS wireing
i beleive on my car they were green and yellow.
Will the speedo work without the computer?
Old Apr 24, 2009 | 10:33 AM
Pocket's Avatar
Car: 91 Trans Am
Re: VSS wireing
http://www.austinthirdgen.org/index.php?pid=19
Scroll down to body wiring. No info on 87's but it should get you started
Old Apr 24, 2009 | 02:57 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
Re: VSS wireing
there's a yellow and purple wire going into that yellow box under the dash.
from there, where do they go? i can't find any yellow and purple wires under the hood other then a yellow going to the windsheild wipers and a big purple going to the starter. do they change when they go through the firewall?
and that schematics did help, but then not really.
what happened is that three years ago, i put in the 400, everything ran good except the speedo didn't work and the oil pressure gauge didn't work (had an aftermarket anyways). i took out the passanger side wireing harness since nothing connected to anything anymore. i still have everything (harness, computers, tpi, etc).
i looked through that passanger wiering harness and couldn't find any yellow wires.
somebody said green and yellow
i do have a green wire not doing anything out of the driver side harness,
//a pink/black stripe and black in a connector, //and a offwhite and a black in another connector. those are the only wires off the driver side that arn't being used.
could the pink/black-stripe with a black wire in a connector be the one? i don't want to start plugging stuff and fry my vss.
Old Apr 24, 2009 | 09:45 PM
Pocket's Avatar
Car: 91 Trans Am
Re: VSS wireing
No, sounds more like the evap connector, but without a pic we cant tell
The yellow box is your buffer box
According to this, if you have power, ground and the VSS input (Yel/Purple) Pin C should output speed signal to the cluster
Cruise and ECM are irrelevant
You've got VSS input, Id check the power/grounds
Old Apr 25, 2009 | 05:05 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
Re: VSS wireing
that wiring diagram is very helpfull, that's the one i was looking for
now, being a novice, i'm trying to associate it with my car.
my goal is to find the correct purple and yellow wire in my car.
is C100 the plug in on the firewall on the driver side?
i have a purple and yellow wire comming out of there, but they go to my windsheild wiper motor.
would an '87 be the same as the '92 diagram?
Old Apr 25, 2009 | 08:14 PM
Pocket's Avatar
Car: 91 Trans Am
Re: VSS wireing
Not in either C100 or C207. Might be in one of the connectors near the ECM (pass side)
Yes C100 is near the booster
Old Apr 26, 2009 | 06:55 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
Re: VSS wireing
it's a pink/black stripe with a nother black wire comming from the driver side harness that goes to the VSS on the transmission
in case anybody looks this up.
Old Apr 26, 2009 | 09:51 PM
Pocket's Avatar
Car: 91 Trans Am
Re: VSS wireing
It cant be, there isnt a slot (let alone two) on the C100 for VSS. The only other connector that goes thru the firewall in the vicinity is the cruise harness and GM wouldnt run VSS wiring thru an optional harness.
Plus, they are the wrong colors. Yel/Purple are generic VSS wires for nearly all GM electronic speed sensors no matter the model
http://www.eficonnection.com/eficonn..._pigtails.aspx
Refer to this for what the connector should look like. Green seal is early style -89, red is later 90+
Old Apr 27, 2009 | 01:42 AM
FF400's Avatar
Car: formula
Engine: 400 sbc
Re: VSS wireing
hrm..
so you guys gave me answers and there is no yellow wire under the hood that goes anywhere other then one to the windsheild wipers. i looked in both harneses, right at the base.
so i figured that the yellow/purple wire under the dash has to go somewhere. so i took an ohm meter, stuck one end on the yellow wire tip, then had my dad under the hood checking connections that arn't connected to anything with the other end. the pink one with the black stripe, on a connector that looks exactly like the one for the pre 89 vss connector (green) light up the meter. so there was connectivity there. same with the purple and the other wire on the same connector as the pink/black stripe..
1987 firebird formula, 305 TPI, 700r4.
Old Apr 27, 2009 | 06:33 AM
Pocket's Avatar
Car: 91 Trans Am
Re: VSS wireing
Sounds like an emissions connector
Remove the C100 and find what pin its on then use the chart to determine what it does
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
Bryan F
Aug 27, 2015 07:28 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
