Speedometer problem
Speedometer problem
Ive searched but cant find anything about it. Its a 91 Camaro RS 305 and it takes 5 minutes of driving until the speedo starts to work fine. After its all warmed up i can turn the car off and start it up later 15 minutes and the speedo will work fine. But after the car cools it will take 5 minutes of driving to work again. what could this be?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer problem
Ive searched but cant find anything about it taking 5 minutes of driving until the speedo starts to work. After its all warmed up i can turn the car off and start it up later 15 minutes and the speedo will work fine. But after the car cools it will take 5 minutes of driving to work again. what could this be?
JamesC
In your original post you failed to mention, for example, the make and year. Camaro speedos were cable driven from 82-89, which might lead a diagnosis in one direction. From 90+ they were electric, which might lead to another diagnosis altogether. I wish you the best of luck in finding a fix for your problem.
JamesC
JamesC
Car: 1982 Camaro Sport Coupe
Engine: 2.8L V6, 2BBL
"Ive searched but cant find anything about it. Its a 91 Camaro RS 305"......maybe you should clarify that it is not an 1891 or a 2091?? It is electric and I know nothing about them, but if you have to run it for 5 minutes before it works, could it be a heat issue, kinda like a cold solder joint?
enough with the joke guys. This was posted in the electrical section for a reason!!! i shouldn't have to clarify that its a 1991. there were no Camaros in 1891 nor is it even close to 2091. i just want opinions for possible speedometer solutions
Uh, actually if you read that closer you'd have realised I was goofing on the other guy, not you! But then I realized you didn't actually have that info in your original post, so technically he was right. Didn't mean to offend you, was just goofing around.
PS: I also tried to help at the end of that reply.
Car: 1992 Camaro RS
Just curious if you ever figured out what was going on. My car is doing the same thing, but it just takes longer to "warm up".
By the way mine is 92 rs, was 305 now 350, and auto.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Does your cruise control work when the speedometer doesn't? That would indicate a speedometer or dash wiring problem.
If the cruise doesn't work when speedometer is dead, it would be a problem either in the yellow "buffer box" or upstream, possibly the VSS (Vehicle Speed Sensor).
From your post, I get the impression that it might be the VSS that needs the transmission to heat a little to engage the gears and start spinning. Have you checked the VSS yet? Are the gears alright?
Lou
Lou
My car is doing that same thing, anyone find a solution?
Also which vss sensor should i buy?
http://www.oehq.com/acdelco-parts_21...0RS%205.0L.htm
http://www2.partstrain.com/store/det...92/SISC12.html
http://www2.partstrain.com/store/det...RBB313301.html
Car: 91 RS, 62 T-BIRD
Engine: 3.1V6, 300hp390, 96ci panhead
Transmission: auto od
I just fixed my speedo and cruise at one shot. I pulled the VSS out of the tailshaft of the tranny and cleaned it up real good with purple power pulled off the gear and chucked it up in my batt. op drill pluged it back in turned on the key reached under the car and ran the drill speedo worked wow! ok put it back in drove it up the road no speedo DAMN jacked her back up pull it back out. and started looking at things real close noticed that the mounting tab just snaps in HUH looked at gear its offset to one side took off the tab and rotated the VSS till I felt resistance of the gears meshing put the tab back on in the detents closest to the resistance point bolted it all back up worked like a charm, cruise control and all.
GeneralIesrussi
Sep 3, 2015 03:23 AM
