Odometer Not turning
Old Jul 23, 2009 | 10:57 AM
CHUCKYAB's Avatar
I have an 86 firebird and the odometer stopped working 2 years ago and its stuck on 22K miles. I need to get this fixed to keep the value correct. My mechanic looked at the cable under the car and its OK, he sais its in the dash. What do I do. ?
Old Jul 23, 2009 | 12:29 PM
GILLIGAN's Avatar
Car: 1992 RS
Engine: BLACK&DECKER AQUARIUM PUMP
Re: Odometer Not turning
Does the speedometer work? If it does this should drive the odometer if the speedo does not work it is possible that the connection came off at the back of the speedo.
Old Jul 23, 2009 | 12:55 PM
CHUCKYAB's Avatar
The Speedometer works. All the guages work except the Mileage clock, and the odometer that you can reset to "0"
Old Jul 23, 2009 | 01:23 PM
GILLIGAN's Avatar
Car: 1992 RS
Sound like it is is the speedo assembly then. I never had one apart.I am certian that the odometer works off the speedometer drive it must have a gear broken. It was working when you bought the car? I
Old Jul 23, 2009 | 01:25 PM
CHUCKYAB's Avatar
According to CARFAX, the miles stopped ticking 2 years ago. I have had it one year but never drive it. By looking at the car you can tell it only has 22k miles, but i will have a hard time selling it with the miles not moving.
Old Jul 23, 2009 | 01:47 PM
GILLIGAN's Avatar
Car: 1992 RS
Not to get off subject but I would not believe that I would be willing to bet that someone trampered with it and broke it. I would check with a local speedometer shop and see what the average repair will cost you or just find a low mileage speedo assembly and replace it.
Old Jul 23, 2009 | 02:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Check this thread - see if any of that helps - it's a great writeup and should be a tech article!
https://www.thirdgen.org/forums/faq-...-fix-pics.html
Old Jul 25, 2009 | 03:49 PM
GILLIGAN's Avatar
Car: 1992 RS
This is why this form is going to be one of the best tools in the box.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
andy74
Sep 3, 2015 08:41 AM
