Help me identify these wires 87 T/A
Old Jul 31, 2009 | 04:35 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
87 305 TPI Trans am
Bone stock except for whatever the hell this thing is
OK, i cant remember if this is stock or not, i remember seeing something similar on my Camaro, but im not too sure, and i dont want to rip apart the dash.
What is this? All of this is located under my dash btw. Its got some fuses in it that dont look stock, and one of them isnt there.
This is some purple wire near the hood release, its unplugged and im not sure what it is. I dont want to just connect it without knowing what it does.
These next two are puzzling, the blue and yellow wires lead to my fuse box, they actually go into it in one of the blank fuse spots, then run down to right under the hood release where the yellow wire ends in nothing, its just got electrical tape under it, and the blue one taps into what i think is a power supply wire. Eventually all of this ends in those two light bulb socket looking things that are hooked into a black and white thicker gauge wire. The kicker is a toggle switch is hooked into this circuit also. This is quite confusing, the black and white wire look stock but im not sure, anyone got any ideas as to what the heck this thing is? The switch also does nothing as car as i can tell.
Old Jul 31, 2009 | 08:15 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Help me identify these wires 87 T/A
Aftermarket alarm wiring. The box is probably long gone.
Old Aug 3, 2009 | 07:42 AM
Saber's Avatar
So im assuming that the white connector thing is NOT stock then?
Old Aug 3, 2009 | 09:26 AM
BigBadLou's Avatar
Engine: TPI
Correct, this is wiring for an aftermarket alarm (I recognized the connector immediately). This is not stock at all.
Hope this helps.
Lou
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
Linson
Aug 21, 2015 02:12 PM
