Wiring Pictures need to identify??
Old Aug 13, 2009 | 01:21 PM
beat91rs's Avatar
I am posting a few loose ends, my car is not starting though it has power to the battery and starter. No turnover clicking nothing and i beginning to beleive its this bumfuc*ed wiring. Any suggestions will help.
Attached Thumbnails Wiring Pictures need to identify??-carwiring-001.jpg   Wiring Pictures need to identify??-carwiring-002.jpg   Wiring Pictures need to identify??-carwiring-003.jpg
Old Aug 13, 2009 | 01:24 PM
beat91rs's Avatar
Re: Wiring Pictures need to identify??
The first pic is an orange wire with two white ones in it from the column.
The 2nd is a wire cluster that has a red and white leading into the shifter console and connects with like 4 wires out of it.
And the third is a aftermarketsecurity that i need to tear out.
Old Aug 13, 2009 | 01:27 PM
beat91rs's Avatar
These are inside the shifter where the red and white wire connects. also shows a few grounds with purple wires?
Attached Thumbnails Wiring Pictures need to identify??-carwiring-009.jpg   Wiring Pictures need to identify??-carwiring-010.jpg   Wiring Pictures need to identify??-carwiring-011.jpg
Old Aug 13, 2009 | 01:30 PM
beat91rs's Avatar
In the 2nd pic the purple and white, and the different red and white lead to this connector under the radio. (picture is upside down, sorry)
Old Aug 13, 2009 | 06:57 PM
Pocket's Avatar
Car: 91 Trans Am
Pic 1 is the resistor wiring for your IGN cyl for VATS
The rest are for the alarm which usually disables the starting system
Use this to fix that mess
http://www.austinthirdgen.org/mkport...n8_starter.jpg
Here is VATS in case they messed with it too
http://www.austinthirdgen.org/mkport...m_pass-key.jpg
First, find out if the system only disables the starter
To do this, turn the key to run and use a screwdriver to bridge the starter
If the car starts and runs then the system is only a starter kill
These systems sometimes also disable the fuel pump. You can tell if the fuel pump primes or not
Old Aug 14, 2009 | 11:26 AM
beat91rs's Avatar
hey thanks. ya i figured that the orange wires were the vats and i gutted the aftermarket alarm yesterday. Most of it was soldered into existing wires so i removed most of that but still a no go. Most likely bc i'm still looking where to plug in the vats lol. But im going to look at the sites and mess with it today and ill prolly have a few questions. So again, Thank you.
Old Aug 14, 2009 | 01:33 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Try this to confirm vats. Remove the drivers kick panel. you will find the starter enable relay there. bypass this by bridgeing the two large wires and see if the car cranks. Most alarms come with a resistor to use to bypass vats for. also look for a relay out of place under the dash as this id often used with the resistor to bypass the vats on remote start systems(maybe alarms too???) hope this helps. Lhated vats so I removed the system. you remove the box which is mounted to the firewall behind the dash and turn it off in the ecm with a custom chip, and remove the starter enable relay. I also wired in a kill switch for the starter
Old Dec 11, 2009 | 09:47 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
the vats has to be pluged in for your car to start, ..... the computer reads a ohms resistance from your key and if the reading isnt there , it will shut of your starter and fuel pump
Old Mar 10, 2010 | 01:35 PM
richy87mintiroc's Avatar
Car: 1991 Z28
Transmission: AT
Axle/Gears: Stock
My 91 wont sart after sitting in storage all winter. I took off the panel under the steering column and I have a brown wire just hanging that should go into the fuse box. Its the same wire you have shown in the pic. Where does it plug into?
Old Mar 10, 2010 | 02:51 PM
Pocket's Avatar
Car: 91 Trans Am
If it drove in there, a wire wouldnt mysteriously disconnect from storage
Start with the basics before you go wire tracing
Glowsock
Jul 24, 2025 03:15 PM
Reddeath210
Oct 6, 2015 08:20 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
