Hey!! I found the "smoke release" switch!!
Old Sep 23, 2009 | 07:32 PM
helomech's Avatar
Ok, I finally decided on a car. It's a "pre-crashed" '92 RS. It's got the typical DPO brainiac 'mods' done to it so I'm getting rid of all the little issues.
I was told that the A/C didn't work and that there's a switch to turn the electric fan on the radiator on. WTF?
So I check the fuses and there's no 25amp fuse in the FAN slot. I throw one in and start the car. I flip the switch for the A/C and it comes on, get's cold and the radiator fan kicks on like it's supposed to. Then... sniff sniff... hm, weird. ah.. there's the smoke. So, I assume that the DPO nicked a wire during his 'mods' for putting the stock stereo back if for a quick sale of the car. I pull the console/dash apart. Remove the radio and start the car, a/c on, etc... smoke. Hm, ok. Coming from behind the controls for the a/c stuff. Take that all loose so it's sitting down low. Now I can see the top of it. Start car, a/c on.. smoke. Oooh! Lookie! That big plastic disc/switch thing made of black plastic has two hot spots, glowing red, burning through the plastic. Sweet! Tracked down the bad part. Pulled it out... guessing this will be a dealer item.
Old Sep 23, 2009 | 07:38 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Hey!! I found the "smoke release" switch!!
i think its an alien space ship...
better bring that to area 51 for further inspection...
lol
what is it?
Old Sep 23, 2009 | 07:43 PM
helomech's Avatar
it's behind the dash. When you move that a/c:heat lever for OFF-MAX-NORMAL-VENT, etc. It moves this 'switch' which has a molded connector that goes to the wiring harness. It's obviously bad and the only thing I need to actually have working a/c and heat... and the radiator fan working properly. Now... to find a chevy dealer that's still in business!
Old Sep 23, 2009 | 10:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'd probably do better on eBay.
Old Sep 23, 2009 | 10:03 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
no chance, thats a junk yard part friend
Old Sep 23, 2009 | 10:09 PM
helomech's Avatar
actually found it available at autozone for about $23.00.
Now if I can find a doubledin stereo that works and plays cd's, I'll be happier.
Old Sep 23, 2009 | 10:10 PM
Chevy8588's Avatar
wow, surprised. what it called?
Old Sep 23, 2009 | 10:14 PM
helomech's Avatar
Duralast/Blower/Heater Switch
Part Number: SW3019
$22.99
I know, I know... duralast... but, well, ya know.
Old Sep 23, 2009 | 10:16 PM
Chevy8588's Avatar
more like Dura-Crap :P
Old Sep 23, 2009 | 11:05 PM
91project's Avatar
Car: 1991 Camaro RS
Engine: 305 c.i. T.B.I.
Transmission: TH700R4
Axle/Gears: stock open 2.72
it's a blower motor resistor you can find it ant just about any parts store
Old Sep 24, 2009 | 11:10 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Duralast is just the name on the box, its a Wells part.
Old Sep 24, 2009 | 11:26 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
+1
Old Sep 24, 2009 | 01:29 PM
helomech's Avatar
Well Autozone has to order it so I stopped in to the local NAPA. Took alot of catalogs and vendor calls, but I'll have one this afternoon.
The number NAPA uses for it is 15-71113 and with sales tax, it was only $18.48!!
Napa's catalog and online didn't show the right parts. Ended up having the vendor fax over a picture of it to make sure it was the right one.
Old Sep 25, 2009 | 10:41 PM
helomech's Avatar
Installed the above part and it would seem that everything is working as it should be. Think I need to have the a/c charged as the compressor seems to cycle on and off more than it should. Will throw a guage on it and see what's going on.
Old Oct 8, 2009 | 06:30 PM
Mike M's Avatar
The alien spaceship thingy in question is the blower motor speed switch. ANY decent parts store should have or be able to get quickly this item. It is not the blower motor resistor. If it were you would only have one speed for the blower and that would be high. The blower resistor is located close to the blower motor and is inserted in the airstream to keep it cool. Usually poor connections cause switch contacts to fail. Clean all of them at the switch location, the resistor, and fan motor connections. Make sure the fan motor is grounded well. Hope this helps.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
ChevyZ71
Aug 13, 2015 07:30 AM
squiggy2
Aug 9, 2015 09:30 PM
