Right turn singal not blinking
Old Sep 24, 2009 | 09:36 AM
CHUCKYAB's Avatar
Hi, I searched the threads before posting my question and had no luck.
When I use my right turn signal, the green dash arrow lights up but does not blink. The Left signal works fine .
When I turn my headlights on, the right arow turns green.
Is this an easy fix?
Thanks again for the help.
Old Sep 24, 2009 | 11:53 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Right turn singal not blinking
Try replacing the Blinker Bulbs... If that doesn't work, Change the side marker bulb.
Old Sep 24, 2009 | 12:02 PM
1Aauto's Avatar
Former Sponsor
A blown bulb would cause that symptom.
Old Sep 26, 2009 | 09:20 AM
mosemac's Avatar
Car: 85 trans am
had the same problem with my 85 TA and it ended up being a loose ground to the blinker. got red neck with it and just jammed it back in there with some aluminum foil, no problems since.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
