Battery Drain
Old Sep 28, 2009 | 10:02 PM
blues15dp's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 Liter 350 V8 TPI
Transmission: Automatic
Battery Drain
I have a slow but annoying battery drain that takes about two weeks to kill that battery. It is being caused by the fuse that runs the interior lights and the horn. I have been preventing by pulling the fuse every time I get out the car but I can't be doing this forever. Also, the original owner had a fan overdrive put in as the right fog light button and had the left fog light button control both, could this be linked to this issue. Any Ideas? Any one ever have the same issue with this fuse before? HELP!
Old Sep 29, 2009 | 12:29 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Battery Is Leaking - Need Drain
You can put an ammeter in line with the suspected PO added buttons and see if they draw.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Sep 29, 2009 | 04:22 PM
blues15dp's Avatar
Re: Battery Is Leaking - Need Drain
Previous owner had the issue, new battery still continuing problem
Old Sep 30, 2009 | 08:29 AM
NINÅ's Avatar
Transmission: 765R4
Use the ammeter to tap into other lines and find which one is drawing excessively.
Happy Racing!
Old Oct 5, 2009 | 06:50 PM
blues15dp's Avatar
Re: Battery Drain
Can't see how the fan is linked to the drain its the interior lights fuse. Any other ideas what could be the source?
Old Oct 6, 2009 | 06:50 PM
blues15dp's Avatar
Re: Battery Drain
Anyone?
Old Oct 6, 2009 | 07:44 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Battery Drain
Well the fan shouldnt be linked into it but then again there shouldnt be a fan override switch either lol. As unlikely as it sounds i have to side with NINA on this one because unfortunetly 80-90% of the time theres a "short" its because someone got into the wiring when they dont know what there doing. My best guess though beyond that would be the radio as it seems again 70% of all shorts in encounter are in some way related to an aftermarket radio that was installed wrong. Has this been going on forever or just developed?
Old Oct 7, 2009 | 05:46 AM
blues15dp's Avatar
Re: Battery Drain
Good question, I'd love to know the answer to. The car is a new one for me. Previous owner had the issue, I believe the original owner installed the fan overdrive instead of the sub woofer control. I'm not exactly sure how long it has been causing a problem, my guess is that the PO had the issue ever since he owned the car also.
Old Oct 7, 2009 | 11:21 AM
Re: Battery Drain
Well at least you know roughly where the issue is. Knowing what circuit its on narrows it down a lot! Again i have a strange suspicion it was something a PO did so i would start by check the fan stuff and the radio. Anything really that you can see has been messed with. Ive also heard of the hatch pull down motor causing an issue but that would likely cause your battery to drain down way faster. Old aftermarket security systems also had a fairly large draw.
Old Oct 7, 2009 | 11:53 AM
1Aauto's Avatar
Former Sponsor
Re: Battery Drain
This isn't a fix for the short problem,but if the car sits in a garage go to WalMart and buy a battery Tender.They're only about 20.00 and kick on when the battery goes low. Would help to keep it up.
Old Oct 8, 2009 | 06:06 PM
Mike M's Avatar
Re: Battery Drain
The fuse you speak of sends power to the Interior light, Horn, Door chime and also maintains power to the radio's memory. Any one of those circuits might be suspect. If you also suspect the previous owner's mess then undo it. An aftermarket radiator cooling fan controller costs about 35 bucks and can be dialed in at any temp from 160 to 225. Get it at any O'Reilly auto parts store. It's made by Hayden.
I don't agree with the soultion of using a battery tender to solve your problem however. Battery tenders are good for vehicles without electrical problems. Simply leaving a car to sit with the battery connected will in itself drain a battery over an extended time. There are numerous circuits left "at potential". To use a battery tender to "solve" your problem will only mask it. Worse case scenario the hidden problem will only get worse until the circuit fails.
Find someone with auto electrical knowledge and isolate each circuit with a multimeter. This is the only true way of repairing your fault.
Good Luck
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
