comp problem? won't turn over, help please
Old Sep 29, 2009 | 08:59 AM
willdog666's Avatar
Car: 1988 camaro sc
Engine: 350 tbi swap
Axle/Gears: posi 3:23 swap
1991 camaro rs convertible auto 305 tbi
Ok here"s the short of it. SHORT i think is the key word. Well 1st thing, idiot that I am I went to hook up a fan relay control switch, and didn't check the wires, the relays were switched and i hooked it to the fuel pump relay, bam killed it assuming i fried a transistor in the comp i ran a hot wire to a switch in the dash and ta da it works. just had to prime with switch. works for approx a month then occasionally nothing. Only clicks in steering column when turning the key then eventually starts. Now won't start at all and the starter is turning some but only trying to grind teeth on flywheel. I go through and check the starter spacing, shim it just in case still won't turn motor over, flywheel won't budge. While checking stuff find blown ecm fuse....replaced fuse now when cranking interior lights flashing starter still trying to no avail...great what did i do.. would the comp keep the engine from turning over, or did i mess something else up in the ignition, any input appreciated..i'm basicly a learning backyard mechanic stuck in a condo without lots of tools...i miss actually having a backyard instead of a parking lot lol
Old Sep 29, 2009 | 09:08 AM
554racing's Avatar
Re: comp problem? won't turn over, help please
the fan relay and the fuel relay are not the same design/shape. The fan is oval and the fuel is a rectangle but the tan w/black wire feed into them both.
Old Sep 29, 2009 | 09:11 AM
554racing's Avatar
fuel pump green w/ white stripe is the relay on and the out of the ecm and the orange is the pump power the red is the tester port under the dash tan w/ blk wire is to the pump
Old Sep 29, 2009 | 09:21 AM
554racing's Avatar
My 89 fan would not work ?? The relay plug was melted and after trouble shooting the only thing could fig out was ECM bad?? I hooked up a after market adjustable fan relay and a junkyard piece of GM fan wire about 7 ft. wired it up according to the dir. and it runs the fan. Just removed the ecm and all of the related crap (ecm) switch to old school dist.intake and carb wating on a intake the one I had was broken only thing I had trouble with was the VATS
Old Sep 29, 2009 | 09:39 AM
willdog666's Avatar
Car: 1988 camaro sc
thanks for the response....no i get that the relays are different, i realized what i did and hooked up the fan switch correctly, fan switch works great no prob the prob is now the the car wont start after miswiring to the fuel pump relay, sorry didnt clarify very well now that i reread it. i have a seperate switch in dash with a momentary fused hot wire running to fuel pump relay to prime it, worked great for a while now nothing after a month or so, starter works engine won't crank at all, blown ecm fuse replaced fuse still no good
Old Sep 29, 2009 | 09:48 AM
willdog666's Avatar
Car: 1988 camaro sc
oh yeah i'm thinking this may have caused the problem or did i wire it up right...i ran the hot wire from the prime switch to the green/white wire on fuel pump relay, should it have been hooked somewhere else, it worked great for a while now nada....
Old Sep 29, 2009 | 08:22 PM
554racing's Avatar
my be time for a new pump its almost 20 now. If you have a 12 pin ALCL connector its the tester diagnostic under the dash above your right knee port A is ground B test terminal C A.I.R. smog pump E serial data F is tcc and G is fuel pump. Make a jumper wire and put it into the A and G. G is hot 12 volts and A is to ground if the pump works there is other problems if it doesnot work prob the pump bad.
Old Sep 30, 2009 | 09:06 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Nope, the computer only controls fuel injection and spark so it won't keep your engine from turning. You definitely have a mechanical problem that you need to sort out first. (if you can turn the engine by hand with a breaker bar, I'd suspect the starter)
Disregard the advice about fuel pump or other electrical components, you need to focus on turning your engine over right now.
Lou
Derick15
Sep 17, 2016 05:28 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
