bad starter grind
Old Oct 1, 2009 | 12:01 AM
cutmesomeslack's Avatar
Car: 1984 GMC. soon to be 1986 camaro
Engine: Carb'd 350
Transmission: TH 350
Axle/Gears: Stock
bad starter grind
ok i just pulled the completely perfect running engine from my truck and put it in my camaro everything it wired up and connected. Its a carb'd engine. I have the larger lead from the alternator connected to the larger post on the starter solenoid along with the wire that powers the inside of the car and then my positive cable from the battery is connected. the purple ignition wire is connected to the smaller post closest to the block. It starts to turn over fine for a second and the a loud poping sound from the starter and flywheel happens. I dont know what it is.
Old Oct 1, 2009 | 12:49 AM
Engine: Carb'd 350
Axle/Gears: Stock
Re: bad starter grind
also i never removed the starter from the engine and it never game me a problem before
Old Oct 1, 2009 | 12:12 PM
Engine: Carb'd 350
Axle/Gears: Stock
I really could use some help I dont have anything to drive right now
Jorlain
Oct 8, 2015 01:57 AM
Blue419
Sep 10, 2015 01:03 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
