Need some help, asap.
Old Oct 10, 2009 | 02:36 PM
beatereater's Avatar
Car: 84 Trans am
Engine: 355
Transmission: TH400
Axle/Gears: 343 rear end
im trying to get my 84 T/A to start, but the distributor has no power to it and i cant seem to find the wire that needs to be hooked up and where to hook it up idk?? i wouldve known how if i tore it down but i bought it with a new engine and all wires disconnected
Old Oct 11, 2009 | 03:14 PM
Car: 84 Trans am
Engine: 355
Transmission: TH400
Re: Need some help, asap.
first off, bump^^. second, i think i found the problem. it was originally an electronic controlled distributor and now i have a vacuum advance. . im thinking that the problem could be no power to the coil, because the guy i got the dist. from said that he tested it and it worked fine.. any ideas?
Old Oct 11, 2009 | 04:00 PM
t_long927's Avatar
First you need to check the Coil for power. Unless it is in the distributor. There should be a plug with like 4 wires that go into it. Take a volt meter and check to see if the coil has any power. Then go to www.autozone.com and get a wiring diagram. it is free to sign up. check the ECU and see if you have power coming out of the ECU. If you don't then you may have a Bad Compute.
Old Oct 13, 2009 | 11:30 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Disturbing Distributor
The coil gets power from a PINK 12 AWG wire which comes from the ignition switch which goes to a 2 pin connector in the engine compartment, that 2 pin connector plugs into the distributor.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
nesluopetan
Apr 9, 2002 05:06 PM
nesluopetan
Apr 9, 2002 03:39 AM
nesluopetan
Nov 5, 2001 02:52 PM
nesluopetan
Aug 25, 2001 11:19 PM
