I don't know what this wire is?!!!!!!
Old Oct 19, 2009 | 04:15 PM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
Ok, its been like this for awhile, and im just wondering what it is. Im thinking it might be the intermittent for the windshield wipers. here are some pics of the wire.
100_1456.jpg?t=1255986896
Old Oct 19, 2009 | 04:26 PM
Axle/Gears: Idk
Re: I don't know what this wire is?!!!!!!
here is another pic.
100_1455-1.jpg?t=1255987548
Old Oct 19, 2009 | 09:56 PM
Axle/Gears: Idk
bump
Old Oct 19, 2009 | 10:31 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
what color is the wire - is it pink with black stripe?
Old Oct 19, 2009 | 10:46 PM
Axle/Gears: Idk
yeah, its coming from the back of the motor, possibly the distributer
Old Oct 20, 2009 | 06:44 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I'll take a look at mine at the shop today and see if I can find it. I have an '88 T/A 305 TPI, so it might be there. Unfortunately the car is at my shop and not my house or I could have looked right away...Ill let you know what I find tonight.
Old Oct 20, 2009 | 07:39 AM
Twin_Turbo's Avatar
pink/black - black usually pink/black is an ignition switched source. Used for many things like the air diverter valve, EGR solenoid, and so one. Also the AC comp. relay gets power from a pink/black. i assume you can't find the other side that goes onto the connector?
Old Oct 20, 2009 | 09:22 AM
Car: 1992 RS
Engine: Carbed 350
Do all your injectors have wires to them? Pink/Black can also be injectors according to my Haynes book. I'm no expert on the TPI - but it does not look like an injector connector - but I thought I'd throw it out there as something to check.
Old Oct 20, 2009 | 12:05 PM
Car: '87 Trans-Am
Sorry, I took a look this morning and no dice for a match on my car. If it belongs in that area for sure, maybe it's for something emissions related and that's why it doesn't seem to be affecting anything. Maybe for a gauge sender or something, the connector looks kind of odd...like emissions or wipers or cruise or something along the lines of not so critical :-p Sorry I couldn't find anything.
Old Oct 20, 2009 | 12:07 PM
Twin_Turbo's Avatar
The connector is just a generic 2 pin weatherpack unit...nothing special.
Old Oct 20, 2009 | 02:27 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Looks to me like MAT sensor but that might throw a code and get a light, but you might want to check that the sensor is plugged in...maybe lol.
Old Oct 20, 2009 | 02:35 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
if its coming from the back of the motor by the dizzy. that wire plugs into another wire that extends to the air temp sensor under your plenum on driver side. i just had this problem. the other wire is about 8 inches long. the end that goes into the air temp is the EXACT same kind of plug that plugs into your hei module. the two prong one. hope this helps.
Old Oct 20, 2009 | 02:36 PM
Axle/Gears: Idk
sounds about right, it could be the problem why my wiper delay and wiper washer dont work. ill go take a look.
Old Oct 20, 2009 | 03:30 PM
Axle/Gears: Idk
i just looked at it, and there is nothing visible that it could plug in to. i took the plastic cover off the back of the intake to expose the dis. cap wires, and i could see the wire comes out of one of the black tubes that holds wires. its pointing toward the distributor cap area. the black tube it comes out of connects to the little black boxes where all the wires are on the drivers side of the car. it looks like id have to take apart the whole intake assembly to fix it. im pretty sure it has something to do with the wiper delay and washer.
Old Oct 21, 2009 | 01:59 PM
Pocket's Avatar
Car: 91 Trans Am
First guess is EGR based on the wire colors and rough location
It is not an INJ connector, wrong colors and connector type. Wiper should be a 3 pin for the small connector. Washer is 2 pin dk blue and red. Its nowhere near that area of the engine bay
MAT/IAT has a 2 pin tan and black connector. Wrong colors for that
Inspect the EGR and EGR solenoid on the rear pass side of the plenum
Old Oct 21, 2009 | 03:05 PM
Axle/Gears: Idk
ok thanks, ill go take a look. what does the egr look like and would i have to take the intake off to get to it?
Old Oct 21, 2009 | 06:51 PM
Axle/Gears: Idk
ok, i looked up the egr solenoid. does this have different names, cuz some look the same and are called idle air control, purge solenoid,, or egr. some are black with a little plug in. and some are silver with just the vacuum line in or out. they all look like the same thing. is one black one with the connector the factory one, or is the silver one an aftermarket one that does not need to be connected?
Old Oct 26, 2009 | 05:04 PM
Axle/Gears: Idk
bump
Old Oct 27, 2009 | 01:23 PM
89IROKCONVERT's Avatar
i agree with bennin 360 thats what it is on my 89 tpi anyway
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
