battery wiring confusion
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
hey guys im wanting to put a battery relocation switch in my car. i want it to run off a master disconnect in the rear. my question is how do i wire it up to the switch and battery?
- i have an idea how but not sure. would i connect the battery wire to the switch, and the from switch to starter?
-also how do i connect the alternator wire to the battery?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: battery wiring confusion
You run the Alt wire to the same terminal on the starter that the pos goes to; is the same polarity +
Engine: 355
ok so i dont need to run the alt wire all the way back to the battery i can just go direct wire from alt to the pos side of starter that battery goes to?
Car: 82 Z28
Transmission: T400
The pos terminal on the starter is effectively the pos terminal of the battery; just relocated.
I believe on your car a lot of the main feeds ( thick red cables ) come from that point anyway
Engine: 355
cool thanks for clearifying that for me. thought it was gna be worse then i thought
Engine: 355
also how do i get the alternator to shutoff when the master switch is disconnected? im thinking of running the pos alt wire all the way back to the battery. do i connect that to the master connect to?
3rd gens use the + side of the starter as a power distribution block. Most cars also got another small one located behind the pass headlight
This is how I ran a kill switch on my racecar. 3rd gen alts use another 12v constant from the starter power dist to function (not shown). Move that to the power dist block and the switch will kill everything
Car: 82 Z28
Transmission: T400
In his ;why does he have to shutoff the Alt, there is no OFF switch for the Alt in a std car? Turning the ign off kills everything
Engine: 355
i was reading that the battery can be killed by the switch but if it doesnt shut alt off to itll keep power at the ignition and keep car running
Engine: 355
ok so just wire the big red wire to the pos side of starter. run the alt red wire back to the battery positive side, and put the switch in between the big red wire going to the starter, and it will shut everything down?
Engine: 355
ok i got the switch and battery all located and wired up out back. now my question is what actually gives the power to the rest of the car? is it the power wire that runs to the starter or the one from the alt to the main harness on driver side?
Car: 82 Z28
Transmission: T400
Engine: 355
i thinkn its the main thick red one that goes to the big thread on the starter. i could be wrong
Engine: 355
i have 2 small wires ones with vlack connector looking things above them, and the pos terminal one for the starter. where would i hook up the 2 small wires at on the selonoid? do i hook them both up to the "s" terminal on selonoid?
Car: 1984 Camaro Z28
Engine: 350ci
Axle/Gears: 3.31 non posi = no traction
My alternator is not set up like this. It just has one wire that goes from the battery to the alternator and then a jumper on the alternator. I am guessing that it is rigged. Is this bad?
Engine: 355
i got pics of what i have. any help is appreciated
Engine: 350ci
So you are running two selonoids? My starter already has one attached to it. What is the point of two?
Engine: 355
helps with the heat soak issue with headers
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 11, 2015 10:11 PM
