10 fuse for gages blows and kills my battery
Old Jan 4, 2010 | 09:22 PM
83 trans's Avatar
i need help i have a 83 trans am and cant find wuts wrong. people try cheating me for money
Old Jan 4, 2010 | 09:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 10 fuse for gages blows and kills my battery
If you are blowing fuses you have a short to ground.
You need to track through any circuits off that fuse and make sure the wiring is good, then check whatever item is on the circuit
Old Jan 4, 2010 | 09:49 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
agreed, there is a short somewhere. The gauges circuit is hooked to the tail light circuit, the interior light circuit, and maybe like the radio circuit to name a few I believe.
Who is trying to cheat you out of money???? A shop??? Finding shorts can be hard...tools needed...test light, multimeter, and wiring diagrams for your car. Also needed are tools to repair wiring.
Old Jan 4, 2010 | 09:50 PM
83 trans's Avatar
thanks
Old Jan 5, 2010 | 12:01 AM
Drew's Avatar
I don't have a reference for a 1983 T/A, but I've got some 83 Camaro info... It might be the same. Anyway... For the 1983 Camaro, the gauges fuse powers the gauges (shocking, I know), warning lamps, seat belt warning buzzer, and the rear window defogger. Any one of those items, or a short anywhere in the harness could be killing the fuse. You'll want to start by finding a wiring diagram for your car that shows that circuit. Then start troubleshooting each part of the circuit until you find the short.
Good luck.
MM2Robinson
Oct 1, 2017 09:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
90formulaVortec
Sep 3, 2015 09:26 AM
