alternator woes
Old Feb 8, 2010 | 07:15 PM
animute's Avatar
Car: 91 RS, 62 T-BIRD
Engine: 3.1V6, 300hp390, 96ci panhead
Transmission: auto od
alternator woes
Hey need a little advice I've got a 91RS 3.1v6 and for no reason I can find an alternator last about 2 weeks. I've checked connections replaced the battery. I'm on alt#3 has any one had a similar problem and whats thier fix.
Old Feb 9, 2010 | 11:35 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: alternator woes
Exciter wire to the voltage regulator not having enough resistance would cause this. The resistance is supposed to be supplied by your battery idiot light and voltage gauge. Is it working? If the wire is connected directly to power it burns out the bridge rectifier (in minutes not weeks though).
Old Feb 9, 2010 | 12:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Alternative Parts
Originally Posted by animute
……I'm on alt#3 has any one had a similar problem and whats thier fix
What is the make and model number of the alternators?
Happy Racing!
Old Feb 9, 2010 | 01:01 PM
animute's Avatar
Re: Alternative Parts
Paladium rebuilts from Advance.
Old Feb 9, 2010 | 01:16 PM
animute's Avatar
Re: alternator woes
I've got a couple of manuals (chilton&Haynes neither very good) this is a cs type alt 4 wire #10 black to bat, #12 red from the starter, 14#brown to 20 amp fan fuse circuit, and a#14 black not on any of the wiring diagrams.
With key off : #12red hot
#14brown not
#14black not
with key on : #12 red hot
#14 brown hot
#14 black not
hot = bat voltage not = zero no inbetweens
Old Feb 9, 2010 | 03:24 PM
NINÅ's Avatar
Transmission: 765R4
Alternative Part
Your voltages are correct.
Try Advances’ Remy NEW alternators.
Lifetime warrantee.
Part number 91303.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 9, 2010 | 03:47 PM
animute's Avatar
thanks, don't ask me how I found a couple of wires crmiped flat under the steering column mount the other day and didn't have time to fix them so this am. I cut out the flat spots and barrel spliced 'em and the damn thing started chargin, and I found a motors manual 91-94 GM for 10 bucks.
Thankyou guys again I've only just joined this site but I've found some answers to some naggin' questions
Old Feb 10, 2010 | 07:16 AM
animute's Avatar
Re: alternator woes
ALASS, I am but a fool. It worked, it was charging, I shut it it off, went inside, an hour later started it up to go somewhere and well its got another "new" alternator now.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
