Turn signal light stays on.
Old Feb 15, 2010 | 12:28 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
When I turn on my headlights, of course the instrument panel lights come on. But my right side blinker indicator stays green all the time, until I turn on the passenger side blinker. Then it fleashes as it should. Any ideas?
Old Feb 15, 2010 | 12:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Turn signal light stays on.
This is typically a symptom of a bad turn signal switch.
Old Feb 15, 2010 | 02:30 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Doing The Right Thing
Do the right turn signal & marker lamp function correctly?
Have you changed a right side bulb recently?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 16, 2010 | 01:23 PM
Engine: 350 S/B
The right side only flashes with the blinker on. The drivers side functions properly. I have changed both bulbs on the right side recently and cleaned out the sockets.
Old Feb 16, 2010 | 02:12 PM
NINÅ's Avatar
Transmission: 765R4
When you say:
If you are saying the right turn signal flashes but the right side marker does not, then that’s consistent with a shorted right side marker socket, and will also cause the dash indicator problem.
Happy Racing!
Old Feb 16, 2010 | 03:24 PM
Engine: 350 S/B
The blinker and front side marker on the right side flash whenever I activate the turn signal.
Old Feb 16, 2010 | 03:36 PM
Stephen's Avatar
Car: 87 GTA
Did you put in a LED bulb? I did & the dash indicator lit up like that. So I switched back to regular bulbs.
Old Feb 16, 2010 | 03:43 PM
Engine: 350 S/B
No just swapped it with a new factory replacement.
Old Feb 17, 2010 | 08:29 AM
jpackard89's Avatar
I had the same problem, even after I changed bulbs. When I bought the car, all the bulbs were 1156 or 1157. They are supposed to be 2056 or 2057... Once I changed them back to what they were supposed to be, everything worked fine. Also check wiring connections. My right front turn signal would short out every once and a while, creating the same problem.
Old Feb 17, 2010 | 06:07 PM
polaris91's Avatar
Car: 88 camaro z28
i had that problem when i replaced my turn signal bulbs because you can put the bulb in 2 ways and i put it in the wrong way so i switched it around and has worked great sence
Old May 6, 2011 | 09:13 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
Shadyredeyes,
I have the exact same problem. Did you ever figure it out?
Old May 6, 2011 | 11:29 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
A poor ground at the turnsignal socket will cause the light circuit to find ground through the turn signal circuit. Check the socket for corrosion or a broken ground tab.
Fronzizzle
Mar 18, 2019 08:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
