Wiring a heated oxygen sensor
Old Mar 1, 2010 | 12:51 PM
bowtieboy42's Avatar
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
So I installed a heated oxygen sensor on my car in an attempt to fix the running like crap problem I have (it didnt help). Anyway, I ran my 12v of power straight from the battery. Came out today, and the battery was dead. In retrospect, this makes sense since I guess the sensor was constantly drawing from the battery (correct?)
Anyway, is there somewhere under the hood I can draw 12v from? Where did everyone wire theres to? Thanks.
Old Mar 1, 2010 | 05:46 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: Wiring a heated oxygen sensor
https://www.thirdgen.org/forums/tech...ht=wire+heated
Old Mar 2, 2010 | 12:31 AM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
I'm asking if theres anywhere under the hood I could wire it into. I already have the wires ran under there, so I'd rather not have to go all the way back to the fuel pump (I did search and read through that thread and many others... Didn't really find a specific answer.)
Old Mar 2, 2010 | 06:59 AM
Pocket's Avatar
Car: 91 Trans Am
Find a 12v switched wire, the emissions common from the C100 is a good one for that. Its fused
Old Mar 2, 2010 | 10:28 AM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Where is that located? Sorry, I'm a little dub when it comes to wiring... Its really not my strong point
Old Mar 2, 2010 | 05:00 PM
Pocket's Avatar
Car: 91 Trans Am
C100 is the bulkhead near your booster. Simplify your hunt, its the EGR/A.I.R. pnk/blk wire
Old Mar 3, 2010 | 03:46 AM
matthufham's Avatar
Car: 90 z28
Transmission: t56
the fuel pump relay is under the hood a few feet from the o2 sensor. one of the 3 relays by the brake booster on the firewall where all the wires go inside.
Old Mar 3, 2010 | 07:31 AM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Okay, I thought the relay was under the body somewhere... Thanks a lot fo-r the replies, I'll get on it today...
Old Sep 13, 2011 | 02:27 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
sorry to drag this badboy up, but whats going on if i dont seem to get power at the pnk/blk wire at any point? ign off, ign on and when its running? i have removed the air pump and all that , would that be why?
Old Sep 15, 2011 | 06:24 AM
Pocket's Avatar
Car: 91 Trans Am
Blown emissions fuse. You can draw 12v switched from any source you like though, this one is easy to find and fused FOR it
Old Sep 15, 2011 | 09:39 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
But ya do realize it doens't need power all the time, it only needs 12v on start up when the car is cold so its heats up quicker. once up to engine temp, it doens't need heated anymore.
Will last 10x longer if you don't feed it 12v all the time.
Old Sep 15, 2011 | 08:21 PM
Pocket's Avatar
Car: 91 Trans Am
It needs 12v switched (IGN)
It will NOT last 10x longer if its not continuously heated. OEM HO2s are run with 12v IGN and can last a decade
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
stalkier
Aug 21, 2015 01:54 AM
beast94
Aug 20, 2015 06:44 AM
fonzie85
Aug 13, 2015 11:50 AM
