Lights: They only work sometimes
Old Mar 4, 2010 | 08:25 AM
casperlord's Avatar
I have an 85 Trans am with the 305 Carburetor.
Last year I was driving around for about 3 months before one day my lighting all went crazy.
The gauges in the car do not light up like they used to. Neither do the back lights when they are supposed to be. As in...I turn the **** to turn on the lights at night and they do not work. Yet, if you press the brake the back lights do light up.
Also, when the switch is turned, the front lights still work. Just the gauges and the back lights.
I dont have as much experience in wiring as other parts of the car so any help would be appreciated.
I started to pull relays and fuses to see if that was it, but like I said, wiring and electrical is not really my speciality.
Old Mar 4, 2010 | 11:40 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Fright
When you use the term “front lights” do you mean headlights, or the so-called parking lights.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Mar 4, 2010 | 10:45 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Lights: They only work sometimes
Check your 'tail' fuse, yellow 20 amp... also check your dash fuse, 'inst lp'(very low amp, 5, I think). The dash lights run through the taillight circuit. The brake lights have their own fuse, not affected by the taillights.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
