Tail Lights turn signal blinking speed
Car: 85 trans am
Engine: 305 tpi
Transmission: 5 speed
When i go to put my signal on the right side, it seems to be delayed inbetween blinks. When i watch it, it looks like it blinks twice as slow as the left turn signal. i changed out the bulbs but i still have a slow blinker.
Could it be a relay, or what? im no expert with electronics.
thanks
thanks
Axle/Gears: 9-bolt/3.45
Re: Tail Lights turn signal blinking speed
I'd begin by replacing the turn signal flasher... simple and cheap from any auto parts store. Here are some samples for your car:
http://www.oreillyauto.com/site/c/se...ird&vi=1251278
There's the tried-n-true Bussmann #552 metal flasher for about $3, or you can spend about $9 for a newer-style electronic flasher. Tip: the electronic flashers are plastic, and they can melt on a hot summer day, so I'd recommend the good ole metal-style.
Now, if you don't know where it's located, that won't be so easy to describe... Most guys would say it's in the "convenience center," but it's not. It's clipped to the metal frame of the dash just above the convenience center. And the convenience center is under the dash between the steering column and the center console, near the diagnostic port.
Remove the underside of the dash, pull down the convenience center, then look up there for the round flasher clipped to the metal frame. Remove, unplug, plug in the new one, test signals, re-clip, and put everything back.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
if your signal flashes faster on one side than the other, the circuit on the slower side has more resistance. likely a loose or corroded connection somewhere.
