Draining battery
Old Mar 2, 2010 | 07:42 PM
evol's Avatar
Car: 1991 Z28 camaro
Draining battery
Alrighty, My battery is draining itself relatively fast. On sunday I had to jump it I thought the battery might have died cause its kinda cold out here and I haven't backed it out and let it run for a week-week and a half. Well today i went to start it up and its dead again (tuesday). Well now im thinking on sunday when i jumped it I got some kind of short or something instead of the cold draining it.
But recently I have replaced a couple things:
Rear brake light up in hatch window
new speakers in behind the sail pannels
Also about 2 weeks ago i did a search for why my power doors hatch and dome light ect wasnt working I came across alot of people saying that the cig lighter was the culprit for blowing the acc. fuse so I found out why all that wasnt working.
But now what i found out when I checked the fuses that there was a 25 instead of a 20 in the acc. and the radio had a 15 instead of the 10 and there was one other with a 25 that was suppose to be a 20
sry for the wall of text i dunno if that last part of stuff was use full or not just wanted to add it all
thnx for help in advance
Old Mar 2, 2010 | 08:14 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Draining battery
Drive the car, get the battery all charged up. Unhook the battery until you drive it again. If it's still up then start looking for the drain. I use a test light between the batt. cable and the battery terminal. If it lights up and stays lit, pull fuses, unhook stuff until it goes out.
Old Mar 2, 2010 | 09:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's a shot in the dark, but ...
Late at night, when it's deadly quiet ... leave the key OUT of the car, open the hatch, place ear on the hump, and listen for the fuel pump. If it's running with the key off, then the culprit is your Oil Pressure Sending Unit (OPSU).
Fuel pump gets a direct battery connection through the OPSU. It's possible for the OPSU to go bad in such a manner that it 'sees' oil pressure when there isn't any. Since the connection is direct from the battery, ignition on doesn't matter - the pump can run constantly without the key. It takes 2-3 days for the fuel pump to drain the battery.
If you hear the pump running (a whining sound) with the key off, try replacing the OPSU - it's located above your oil filter, runs about $30.
Old Mar 3, 2010 | 01:05 PM
evol's Avatar
By hump do u mean the flat part in the trunk behind the back seats?
Old Mar 3, 2010 | 05:14 PM
Car: 1992 RS
Engine: Carbed 350
Yep! You can usually hear the pump running when it's quiet and you have youe ear right against it.
Old Mar 6, 2010 | 11:38 AM
evol's Avatar
Alrighty so today I got sometime to jump it and see if the fuel pump kept running. I shut the car off in the drive way around mid day(quiet town). I could hear it run for cpl sec after i shut the car off whine pause whine pause whine pause kinda deal. Then I pulled it back in the garage and checked it again same deal.
While I was at it I checked all the fuses under the dash with a 12vdc Automotive tester by DORMAN. I put it on all the metal tips on the plastic end of the fuses and the light never came on. (so if im using the right thing as far as i can tell no drain there)If i did this wrong or used the wrong thing let me know and ill get/do the right thing.
Also I unhooked the battery as well
Old Mar 6, 2010 | 02:10 PM
Car: 1992 RS
Engine: Carbed 350
So, the pump stopped all together after a couple of seconds, or it kept doing this "whine pause whine pause" thing forever?
You wouldn't have to start the car for it to run (if it's a bad OPSU) - it'll run always whether the car's been touched or not - you could put the key in the mail to me, and the pump will run long after the post office lost the letter (or the battery dies) if it's a bad OPSU.
The pump shouldn't make any noise after the key is turned off - so that OPSU might be the culprit.
Old Mar 6, 2010 | 05:21 PM
evol's Avatar
It ran(fuel pump) long enough for me to turn the car off(had to jump it and let the battery charge back up) hit the hatch button get out and put my head down to the hump and hear it for like 3 seconds
Old Mar 6, 2010 | 11:40 PM
19transamtpi86's Avatar
Car: 1986 Trans am-Firebird
Transmission: Stock
Well you can try a parasitic drain test but you will need a Digital multimeter that can read amperage. all you do is unhook the positve bater calbe place the pos. lead of the meter to the bater and the neg. lead to the positive batter cable if you read over 100 miliamps then you have a drain anything under is usualy ok. but from there start pulling fuses until the amerpage drops and theres your problem
Old Mar 7, 2010 | 10:09 AM
evol's Avatar
Alright I went out this morning wanted to check if the battery still had a charge after i unhooked it last night and its dead this morning (got a battery tester and it showed it on yellow last night when unhooked it now its red)goes from green yellow red from full to dead
Does this mean the battery is junk?(It was brand new like maybe a month old)even then could be defective
Old Mar 7, 2010 | 10:21 AM
bcmag's Avatar
sure sounds like it.check open circuit voltage with voltmeter.or tke it back where you got it and let them test it.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
