Battery Issue
Old Mar 7, 2010 | 04:56 PM
janson327's Avatar
Car: 1982 Z28, 1983 Z28
Engine: 5.7L 530hp, 5.7L 430hp
Transmission: TH350, 700R4
Axle/Gears: Ford 9", 10 Bolt 3.23
Battery Issue
Hey all,
have an 83 Z28, and my battery terminals have basically glued themselves to the battery, they won't budge even with Vice Grips, and I have now stripped the negative terminal bolt so bad nothing grabs it anymore. Battery is swollen and is no good.
My next idea is to unplug the negative and positive leads from wherever else they are attached too. Where should the nearest connection points be for the positive and negative cables so I can simply unhook the cables and pull them and the battery out?
Regards,
Jon
Old Mar 7, 2010 | 07:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Battery Issue
are you planning on trying to keep the cables? if not just cut them off the battery first. Cut the ground first, then the positive, no arcing that way. dont cross the leads. Then get now cables. probably not a bad idea anyway
if you try to pull everything out, there should be a small wire going right to the fender, the negative is usually bolted to the front of the head or one of the accessory brackets, sh0o0uld not be too hard to trace. The positivfe goes to the starter, and asmaller wire to the alternator, maybe another one or two small wires connected right by the battery. You should be abot to trace them all out.
the problem with trying to unbolt them from the car and remove them as one piece is that if the battery has any charge at all left in it, if the positive touches the car, it will arc, and trying to fumble with both wires at the same time can be dangerous.
Old Mar 7, 2010 | 10:46 PM
janson327's Avatar
Re: Battery Issue
Fair enough, I will cut the terminal ends off and remove then take out the battery. Its safer that way.
I will see if I can buy some replacment terminal ends first, so I can just put new ends on along with the new battery. Otherwise I will be shopping for a whole new wire setup.
Thanks for the help.
Old Mar 8, 2010 | 06:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Battery Issue
Just about any auto parts store carries new ends.
Old Mar 8, 2010 | 06:59 PM
janson327's Avatar
Re: Battery Issue
Just thought I would ask here in case there was any hints and tips. Got it all done today and she is running like a charm.
Thanks all!
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
WIzmo
Aug 30, 2015 02:30 PM
djmarch
Aug 9, 2015 05:27 PM
