90 camaro rs key problem
Old Mar 15, 2010 | 11:28 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
hello everyone.
i have just rebuilt the motor to my car. its a 350 non ecu motor. however i was replacing the ignition switch and it didnt work due to the chip thing i have on my ignition key. i have heard that it is connected to the ecu. how can i get by with that since im not using the ecu anymore.
think my best bet will be to get a whole steering column from an older camaro whom doesnt have the chip/resistor?
need help guys!! thanx!!!
Old Mar 15, 2010 | 11:45 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 90 camaro rs key problem
Originally Posted by antsZRS
hello everyone.
you will have to install a resistor I think... there is plenty of info... search for "Vats" .. .it will give you the detailed step by step tutorial to pin point the actual type of resistor you will need...
Old Mar 16, 2010 | 08:37 AM
richy87mintiroc's Avatar
Car: 1991 Z28
Transmission: AT
Axle/Gears: Stock
hello everyone.
I bought an adapter for about $17. You unplug the ignition wire an blug in the adapter. My car fired right up after waiting about a minute with the key in the run position. It keeps from haveing to replace the ignition or key.
Old Mar 16, 2010 | 01:34 PM
antsZRS's Avatar
Engine: 350 SBC
Kool!!! Thanx!! Hey richey, Can you tell me what the part is called? So I can try it. Right now I have it on a push start. Button I installed while I try to figure this off.
Old Mar 16, 2010 | 09:07 PM
Car: 1991 Z28
Transmission: AT
Axle/Gears: Stock
adaptiveperformance@earthlink.net is the contact. He will just need to know your resistance on your key. Thats easy to get. I assume this adapter is just a resistor in a box. Nice clean look. NO cutting wires or any of that. Looks stock actually. Its called a vats bypass module. Heres a picture. Let me know if you have questions. If the issue is your key or ignition because of the pellet on the key. Than this should do the job.
Old Mar 16, 2010 | 11:06 PM
Fuzzman17's Avatar
Car: 92RS
Engine: 305 TBI
Transmission: 700
Changing the steering column wont help.
I had a lot of trouble with mine. What I did was to read the resistance on my key and then buy resistors that equaled the resistance on the key. I then soldered them into the harness coming from the IGN to the vats module after cutting the harness between the IGN and the plug on the harness. that allowed me to remove it from the car for soldering. They where 2 very light gauge wires that go into a small connector that looks like the connector on a motherboard for the power switch or system speaker.
If you have removed the ECM you could just bypass the starter relay for the vats. On my 92 RS it's near the fuse box and has 2 heavy gauge yellow wires that go from the IGN switch to the starter. Connect these 2 wires together to bypass the relay. (your wire colors may be different.) A jumper wire of the same gauge with 2 spade terminals on it would do it.
If you use the first method you can remove the resisters to disable the starter.
Old Mar 16, 2010 | 11:42 PM
antsZRS's Avatar
Engine: 350 SBC
thanx for the imput fuzzz,
im gonna try the second route you told me and see if i can go from threre.
Old Mar 18, 2010 | 07:38 PM
Car: 1991 Z28
Transmission: AT
Axle/Gears: Stock
The adapter does all that for you. You just unplug the wires and plug in the adapter. It takes all the soldering and cutting wires out of the way. Its cheaper to do the cutting yourself but it's just too much to do in that tight of an area. Good luck. Either way you get the same results. A running car!!
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
wayshegoes
Aug 17, 2015 12:00 PM
tnrednneck
Aug 13, 2015 08:57 AM
