no power to anything
Old Mar 29, 2010 | 07:17 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
hey i am new to the forums i own a 89 firebird with the 305 tbi engine. i have a few questions, i bought this car 2 days after christmas 2009 and i recently started working on it. at first it fired up all ok and everything worked. only thing i did to engine so far was spark plugs on march 20th.
now my problems that i am having are the battery keeps dying and wont stayed charged, nothing in my interior works, my rearview mirror map lights dont turn on, my dome light dont turn on, my light under the dash dont come on. my hatch release button wont open the trunk. and my fuel gauge reads past fuel onlything i have in there is 3 dollars, and my trip odometer no longer flips it back to 0. my headlight motors dont pop up. when i start the car all it does is crank wont turn over even put more gas in and kept adjusting the timing.. all i get is fire through the throttle body every single time whether the timing is advanced or retarded. and my side mirrors dont adjust anymore. im sorry to post such a long thing but i just want to get as much help with this as possible. im only 16 and this is my first car. thanks for any help that i get
Old Mar 30, 2010 | 08:28 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Drain Game
The priority is you need power to fix the other problems so we’ll address the battery problem first.
Sometimes the under-hood light does not go out so check that easy one first.
Then connect an ammeter in series with the battery.
(You can use a small bulb such as a side marker bulb if you don‘t have an ammeter.)
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time till you see the current drop.
That’s the circuit with the problem.
Happy Racing!
“He must be cheating - because I was and he almost beat me.”
Old Mar 30, 2010 | 10:18 AM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
Re: Drain Game
well once i get that fixed what about everything else like not starting and all them other problems i have
Old Mar 31, 2010 | 10:40 AM
NINÅ's Avatar
Transmission: 765R4
Start Here
Once you make sure you have no battery drain you can start the start problem.
You said it ran when you got it, then you replaced the plugs, and now it won’t start.
How sure are you that you got all the spark plug wires back on the correct locations?
Happy Racing!
“After The Fourth Barrel Roll I Lost Control Of The Car”
Old Mar 31, 2010 | 02:58 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
Re: Start Here
Happy Racing!
all the plugs have their cylinder number written on them.. im not sure if they are right though because there was so many other things i found that were messed up on it and on backwards. how can i make sure that the plug wires are all there right cylinder and firing order?
Old Apr 1, 2010 | 08:43 AM
NINÅ's Avatar
Transmission: 765R4
Place Your Order
Here’s the firing order.
Happy Racing!
“Does The White Flag Mean He’s Surrendering?”
Old Apr 2, 2010 | 08:56 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
Re: Place Your Order
Happy Racing!
well i replace all my plug wires today so i know that this is not the problem.. and i noticed today that my vats security light is light up and it stays lite up. could you maybe send me a diagram of how to hook up the bypass. i had bought the prebuilt one but dont know what wires go to where and how its done
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
