V6 to V8 speedometer HELP???
Old Mar 30, 2010 | 09:29 AM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
I am changing my gauges from ( V6 ) TO ( V8 )!
i need to know a couple of thing?
will i need the wiring harness to the V8 gauges... an if i do were do they plugin at??
an Will i need the computer???
Old Mar 30, 2010 | 09:46 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: V6 to V8 speedometer HELP???
If they are from the same years, then just swap them. There is nothing extra needed. There is only 2 things you need to watch for.
1 - Make sure you swap in the correct speedo. Some were mechanical using a cable turned by the trans and some were electronic working off a pulse sent by the trans.
2 - Your Oil Pressure gauge may not read properly with the new one. Many V6 cars only had a "dummy light" oil pressure sender that basically just shows that there IS oil pressure and most V8 cars had a real oil pressure sender that changed its output based on how much pressure there is.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
