How do u deflate the lumbar seats in a TA?
Old Mar 31, 2010 | 01:34 AM
stan12777's Avatar
ok both my seats lumbar dosent work, i press the buttons but i hear nothing, now i only care about deflating my seat... any way i can do that? also is there a fuse or a relay that could be gone??? thanks
Old Mar 31, 2010 | 08:57 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Re: How do u deflate the lumbar seats in a TA?
The fuse is an inline fuse located under the driver's seat.
The middle pic in this post shows the fuse.
https://www.thirdgen.org/forums/post...75-post18.html
Last edited by 1988GTA500HP; Mar 31, 2010 at 09:01 AM. Reason: Edited to add link.
Old Mar 31, 2010 | 11:35 AM
stan12777's Avatar
thanks for the info, but how hard is it to locate? do i need to take the seat out or can i just the carpet and get at it?
Old Mar 31, 2010 | 11:49 AM
Car: 1988 GTA
Engine: 400 CI
Well I took the seat out to help another member figure something out. Judging from the picture, I think you could probably just reach under and find it.
Old Mar 31, 2010 | 11:57 AM
Car: 1988 GTA
Engine: 400 CI
Well I just went out and checked and I was able to get to the fuse by moving the seat all the way forward and face-planting on the rear carpet.
Old Mar 31, 2010 | 06:59 PM
stan12777's Avatar
thanks, i found it and i took out the fuse but it was good, i guess maybe the pump quit working on both sides that is !!! ok whats the best way to deflate the seat then? i have too much lumbar...
Old Apr 1, 2010 | 05:05 AM
Car: 1988 GTA
Engine: 400 CI
The pump, which is the big black box mounted under the front area of the driver's seat, is used for both seats. There is only 1 pump. I do not know how to deflate the seats without the button working. You could try disconnecting the hoses.
Old Apr 1, 2010 | 08:59 AM
stan12777's Avatar
yeah i see the pump, i guess its not working....im gonna try unplugging the hose i guess and see what happens, now with the seat fully deflated u dont think its gonna be too uncomfortable do u ? cause there is no turning back after unplug the hose and deflate it....
Old Apr 2, 2010 | 05:52 AM
Car: 1988 GTA
Engine: 400 CI
No I don't think it will be uncomfortable at all. If removing the hose works, then just pull the hose, let some air escape, and re-attach the hose until you reach your desired firmness. Or get a pump at the JY.
Old Apr 2, 2010 | 11:56 PM
stan12777's Avatar
thanks for ur input, im gonna unplug that hose here when i have some time.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
