car dies
Old Apr 1, 2010 | 01:21 PM
bnb0221's Avatar
car dies
im new here, maybe somebody can help me out. i have a 92 rs with 121k 305. when you r driving it the rpms will jump a little then die. chevy dealer, and couple of other people said its the switch, i have changed the switch and key, and the car is still doing the samething, so can anybody help me out?
Old Apr 1, 2010 | 03:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
All Wired Up
Wire up a small 12 volt bulb (a side marker bulb works best).
Connect one lead to the coil primary, the other lead to ground.
Mount it in the cockpit so you can see it while driving.
The next time the ignition shuts down observe if the bulb is still illuminating.
Report findings.
Happy Racing!
“Does The White Flag Mean He’s Surrendering?”
Old Apr 1, 2010 | 03:21 PM
bnb0221's Avatar
Re: All Wired Up
ok ill do that if the bulb stay on? off what?
Old Apr 1, 2010 | 04:18 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: car dies
Does the car start directly after it dies ?
I would check the fuelpressure, measure the injectors, check batteyr voltage and ground wires.
If the car starts right up after it dies I doubt its the switch (ignition switch and/or key cylinder)
Old Apr 1, 2010 | 04:32 PM
bnb0221's Avatar
Re: car dies
yes it does start right back, and when u put it in gear it will die, then start back put it in gear and drive it thenn it might die or not. i think the batt is good i will check wires again
Old Apr 1, 2010 | 04:53 PM
Theking's Avatar
Car: 1989 IROC-Z
Re: car dies
Have your IAC checked could be failing to add steps to maintain proper idle.
Also check your dizzy so the terminals are fresh and not full of corrosion etc (good spark is always the way to go)
Also use an VOM and measure the resistence of your injectors should be between 14-16.8ohm (approx) and they should be close to each other not very very different.
Its easy to measure and check if they have proper values, then have your fuelpressure checked, on idle, in gear and some higher RPM.. (pressure should rise with RPM)
Old Apr 2, 2010 | 09:58 AM
NINÅ's Avatar
Transmission: 765R4
All Wired Up
If the bulb stays on, you know that it is not the ignition switch, nor any of the wiring in that circuit.
If the bulb goes off it is a problem in the power feed at the ignition circuit.
Use the
B side of the primary for this test.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Apr 3, 2010 | 02:19 PM
bnb0221's Avatar
Re: All Wired Up
hopefully i can work on it quick. a freind of the family said his son 92 did the same thing but it was do to aftermarket stereo ( blue amp wire) said the theft system was messed up. the family member i just got it from just installed a new system in it and it didnt do this until after. i talk to the guy we bought it from said he never had a problem with the car. so i wonder if this is true about the stereo or not.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
