Shift light comes on in an automatic?
Old Apr 12, 2010 | 02:20 PM
Dirks92CamaroRS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
The shift light comes on in my gauge cluster and I have an automatic? Only when I am at at steady speed, if im not on it at all or giving it gas it is off. Anyone know how or if this can be fixed or even if its normal?
Old Apr 12, 2010 | 03:49 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Shift light comes on in an automatic?
Just follow the steps said to remove it. That or black electrical tape over it for the time being
https://www.thirdgen.org/forums/elec...-activate.html
Old Apr 13, 2010 | 07:44 AM
Car: 1992 Camaro RS
Engine: 305 TBI
Hey thanks for the link. I may just take my cluster out at change some bulbs anyway because the right half of the cluster isnt lighting up besides that damn shift-up light!
Old Apr 16, 2010 | 11:13 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Did your cluster get changed? There shouldn't have been a bulb installed for the shift indicator on an automatic. If the bulb is installed and you have an automatic, the shift light will come on whenever the overdrive kicks in. You might want to keep the light there and use it as an economy reminder, to let you know when the overdrive is on and you're getting better fuel economy.
Lon
Old Apr 16, 2010 | 11:19 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
why wouldnt you be able to tell you are in overdrive?
the difference in RPM should be enough for anyone who isnt blind AND deaf
Old Apr 16, 2010 | 01:49 PM
Car: 1992 Camaro RS
Engine: 305 TBI
I did take my cluster out one time because a few of the lights were not working. I could have put one of the bulbs back in the wrong spot? And it comes on no matter what gear it is in as long as I am just cruising
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
