HID Trans am headlight conversion
Old Apr 14, 2010 | 12:58 AM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
http://cgi.ebay.com/ebaymotors/ws/eB...38988263542951
I found this kit, is this a good deal? is it everything I need to convert my car to a modern looking headlight?
Old Apr 16, 2010 | 04:04 PM
Camaros4Life's Avatar
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
Re: HID Trans am headlight conversion
I kno this doesnt help but i was thinking of ordering the kit for my camaro.
http://www.prostreetlighting.com/pro...RSION-KIT.html
I actually was looking for the exact answers lol
thanks for starting post
Old Apr 16, 2010 | 05:04 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
DONT BUY THAT !!!
i had a set like that and the lenses fill up with water while the headlight is flipped down.
Old Apr 16, 2010 | 05:07 PM
regal301's Avatar
Car: 1988 iroc-z
they sell direct fit xtra-vision & silverstar headlamps.thats the way i went
Old Apr 16, 2010 | 06:52 PM
Car: 84 Camaro
Where did you purchase them from?
Old Apr 16, 2010 | 07:00 PM
regal301's Avatar
Car: 1988 iroc-z
autozone
Old Apr 16, 2010 | 07:02 PM
regal301's Avatar
Car: 1988 iroc-z
http://www.autozone.com/autozone/cat...&parentId=57-0
Old Apr 16, 2010 | 08:32 PM
Engine: 2002 Ls1
Transmission: t-56
DONT BUY THAT !!!
they do? are they plastic? did you end up getting another kit? why did they fill up? arent they sealed?
Old Apr 16, 2010 | 10:07 PM
regal301's Avatar
Car: 1988 iroc-z
you get a plastic housing that replaces the sealed glass headlamp,then you can use composite style bulbs in them.the way there vented and where the bulb goes in the back,they werent designed to be flipped down as in our firebirds.
i keep my car garaged but i left it out the night i put them in and the next day they had water in them.
i pulled them out of the car dried them out and put them in my s10 and they never got any water in them after that.i put silverstars in my car and was done with it.
i dont think any of them are designed to be flipped down.and i dident want to half *** them with silicone or anything.i paid $75 for them and they were pretty good looking,i wanted to get hid's too but the thought of a $100 bulb getting wet.......forget that.
I CANT SAY ALL THE HOUSINGS WILL LEAK BUT YOUR REPLACING A SEALED BEAM WITH A COMPOSITE HOUSING THATS VENTED AND NOT MADE TO BE FLIPPED DOWN LIKE IN A FIREBIRD,I THINK THE WATER WILL EVENTUALLY GET IN.
Old Apr 20, 2010 | 01:23 AM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Its not real HID, it Halogen, real HID kits have ballasts for each bulb. I can't say if they leak or not, but have seen others that don't the blue halo on ebay.
You can buy those and install 9004 True HID's but people are bringing up a good point. Are they vented? Check with seller, they certainly need to be sealed water tight...The glass bulbs don't yellow like plastic does over time.....
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 21, 2015 01:54 AM
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
