Stock Radio Needed for 83 Z28
Old Apr 28, 2010 | 04:47 PM
kobrak's Avatar
Car: 1983 Z28 Camaro
Engine: 350 block with original Cross Fire
Folks, anyone have one out there I'd like to get it I've gone through two since getting the car running. I haven't figured out what I am doing wrong as far as firing the thing up? Seems to work for a bit, then poof.....no radio? Cassette still works though. I am using the factory service manual to wire it up and all seems well until she blows!
Is there a subtle difference in years that I'm not aware of? Maybe I'm getting an 86 and it looks the same, but the back wiring is different?
Thanks for any help folks!
Old Apr 29, 2010 | 12:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Can’t Hear Ya Spotter, The Radio Blew Again
If only 2 radios went defective it could be a coincidence.
You’re connecting the power properly otherwise it would never have worked.
Are you running more speakers than stock?
Happy Racing!
Just One Of Them Racin’ Deals
Old May 1, 2010 | 10:14 PM
kobrak's Avatar
Re: I Can’t Hear Ya Spotter, The Radio Blew Again
Stock speakers I guess I'll give a third one a try?
Old May 3, 2010 | 10:06 AM
NINÅ's Avatar
Transmission: 765R4
When you say “blow” do you know what part of the circuitry is failing?
Are you getting a refund for the failed units?
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old May 7, 2010 | 08:15 PM
kobrak's Avatar
Re: Stock Radio Needed for 83 Z28
One literally smoked, the one that is still in the car didn't smoke, but the radio does not work any longer nor do the lights light up, but the cassette player still functions? Strange eh?
Old May 10, 2010 | 11:38 AM
NINÅ's Avatar
Transmission: 765R4
Yup.
Maybe there are voltage spikes damaging the radios.
You can put a dc filter in line with the next radio.
Happy Racing!
Does The White Flag Mean He’s Surrendering?
Old May 12, 2010 | 07:09 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
sounds like probably was just the two radios were bad,
especially the one that now only plays tapes-probably
only needs solder joint repair,typical problem with 3rd
gen era radios.
If you cannot find one,i could check my stash of radios
-do you want exact '83 style with yellow LED display or
is later green VFD display version ok?
Old May 14, 2010 | 11:09 AM
kobrak's Avatar
hhmmm, soldering? I'll pull the thing first to see what I can see and then I'll let you know about getting another one
colton_carlson
Mar 8, 2019 12:21 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
