Starter slow when hot
Old May 28, 2010 | 07:36 PM
Chuck's Avatar
Starter works fine when engine is cold.
When engine is hot, barely turns it over, but eventually starts.
New battery; so that is not the problem.
Any ideas?
Thanks!
Old May 30, 2010 | 10:35 PM
Sledge84's Avatar
Car: '84 Z28
Engine: 383 Stroker
Re: Starter slow when hot
How close does your exhaust run to your starter? My LT headers run right next to my starter and if I drive for a bit I usually have to let it cool down before I can try and start it. While looking around for solutions a guy at Jeg's told me to swap a ford solenoid to it and that would keep it away from the exhaust and working better. I'm going to see if I can't get some header wrap and maybe fab up some sort of shield for it first but I might be looking more into the method he went with. Said he had a BB running 9's on the spray and with that setup it turned over no problem no matter the situation. Let me know what you do and how it works.
Old May 30, 2010 | 11:21 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Classic starter heat soak. In most cases they do not turn at all, and a tap with a wrench or hammer usually motivates it. I would definitely think about removing that boat anchor of a stock starter and put in a high torque mini starter. The size/weight difference alone is worth it, and it will sit farther away from hot exhaust components. Swapped to one myself for the very same problem you are having
Will
Old Jun 2, 2010 | 08:58 PM
Chuck's Avatar
Thanks for the suggestions guys.
Hey, Will, where did you get the "high torque mini starter"?
C
Old Jun 3, 2010 | 12:15 AM
norcalz28's Avatar
Most parts places will have them, I have a hitachi mini starter, but there are many brands, Just tell them you want a mini starter for a small block chevy.Also check summit
gta892000
Aug 11, 2019 11:16 AM
mcbitchman
Sep 30, 2015 01:00 PM
sahlomonic
Sep 20, 2015 07:15 PM
corey8084
Sep 17, 2015 02:56 PM
Formula_88AE
Sep 3, 2015 01:47 PM
