Camaro with no key
Old May 29, 2010 | 11:36 PM
Guest
Guest
Posts: n/a
Camaro with no key
I bought a 1990 camaro that was a repo. Have a major problem, no key. I changed the ignition, and still cant get it going. Can some one explain to me how resistors work? And instructions on what to do.
Old May 31, 2010 | 04:16 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Camaro with no key
https://www.thirdgen.org/vats_passkey_system
Old May 31, 2010 | 09:00 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
thats interesting. i dont even need my key to start my car.
Old May 31, 2010 | 09:08 PM
travis401's Avatar
Car: 91 Camaro RS
You probably either dont have VATS, or have it bypassed. And it sounds like you need to replace your ignition lock cylinder.
Old May 31, 2010 | 10:07 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Because yours is an 87.
VATS started in 89, but it was possible to have a GTA with VATS in 88.
Old May 31, 2010 | 11:28 PM
tgraham77's Avatar
Car: 92 RS-2007 Tundra
Engine: 375hp/350-384hp/5.7l
Transmission: 4 spd auto-6 speed auto
I believe the series of resistors you need totals 875kilo ohm, the unit of measurement for resistance is an ohm. my ignition grenaded and i wired resistors from the electronic shop together (in series)then wired them soldered this configuration between the wires that are in the ignition on the steering column. (When you take apart the ignition it will be obvious))The original key has a resistor in it that would allow the car to start, by using what i say it should fool the computer and you only need a regular key to start the car. If I find my old broken key i will measure the resistance and post so hopefully i am right. The resistors might cost ya 10 bucks.
Old May 31, 2010 | 11:30 PM
There's like 12 different "ohm readings" for VATS, not just one, though.
Old May 31, 2010 | 11:32 PM
travis401's Avatar
Car: 91 Camaro RS
15 to be exact.
Old May 31, 2010 | 11:40 PM
Originally Posted by travis401
15 to be exact.
Eh, I was close.
Old May 31, 2010 | 11:56 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Might want to call a locksmith and let them figure it out. My locksmith charges me 40.00 for a reg key. 100.00 for a chip key. but then again i get a discount cuz i own a towing business. u might want to show the locksmith the original ignition and see if he can help you. GOOD LUCK!!
Old Jun 1, 2010 | 01:02 AM
JT's Avatar
JT
Community Administrator
This explains that VATS started in 1988 on the GTA; the majority of the 1988 GTAs received the VATS system (6,440 of 9,765 US)
http://www.gtasourcepage.com/Pontiac...8cdbs/88F5.jpg
Old Sep 27, 2023 | 02:02 AM
CodyF-iroc87's Avatar
Ya I have an 87 iroc z28 and I just turned it over and started the car without a key. I don’t know what’s going on
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
tnrednneck
Aug 13, 2015 08:57 AM
