Let's play name that plug and what i goes too!
Old Jun 3, 2010 | 08:58 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i found plug number 1 near the alt on the passenger side, its round and has two prongs, whats i go too?
Old Jun 3, 2010 | 08:59 PM
Engine: L31 350
Re: Let's play name that plug and what i goes too!
and plug number 2 is up near the firewall next to the three relays
Old Jun 3, 2010 | 10:28 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
First one looks similar to the back plug of a AC compressor. Second no idea, Wiper motor?
Old Jun 3, 2010 | 10:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
ESC connector.
If not connected to other half you have no spark advance
Old Jun 3, 2010 | 11:51 PM
Engine: L31 350
the plug is to short to reach the compressor
Old Jun 4, 2010 | 12:06 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
It could also be to the high pressure sensor on the high side ac line before the evaporator and after the condenser.
Old Jun 4, 2010 | 04:33 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
The first goes on the ac line thats mounted to the top of the frame rail on the passanger side.
Old Jun 5, 2010 | 04:06 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
What color is the wire running into the single wire connector? Wipe the carbon and junk off of it. If it's tan and black, it will be the ESC connector. If not, it's still a mystery. However, that wire is SUPPOSED to be on the other side of the engine (in the conduit with the ignition coil wires).
The second one is the fan switch for the A/C system you are missing (pressure switch for the fan relay). If not connected to anything or if you don't cut it off and twist the wires together (if not keeping A/C), the radiator fan WILL run every second the ignition is in the RUN position. Been there as well.
Old Jun 5, 2010 | 09:30 PM
Engine: L31 350
i found the ECS connector on the passenger side of the engine, really that single wire plug looks really dirty inside so im starting to think it didnt go to anything, and ill try and find where that other plug goes too, dan where does it connect too? im not seeing any open spots to where it could connect too.
Old Jun 5, 2010 | 10:20 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That's because the PO of your car decided to half-a$$ an A/C delete and you have no A/C lines, accumulator, condenser, or evaporator. The switch would be screwed into a fitting on the high line running to the accumulator (I think), which you obviously don't have.
Old Jun 5, 2010 | 10:42 PM
Engine: L31 350
i have my ac lines and my condenser back lol, i didnt know i was missing other parts though
Old Jun 6, 2010 | 03:05 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The fitting to the switch should be on the pipe running along the frame rail towards the heater/A/C case on the firewall. It'll be down near where the rubber hose from the charcoal canister connects to the metal line running from the fuel tank.
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
