What are these 2 wires for????
Old Jun 7, 2010 | 04:49 PM
Irocz_89's Avatar
Car: 1989 Iroc-Z Camaro: Sold :(
Transmission: Built 700r4
Okay, So I recently swapped over from a 305 TBI to a 305 TPI, I swapped out the TBI engine for a TPI engine. I have a 305 TPI ECM running it and it still wants to stall and cut out. Also has a ruff Idle. I made sure MAF is good and everything. But I came to the conclusion that it may be something with these to wires that are not connected to anything. I know they have to do something but I couldn't figure out what they are for. They are from the wiring harness originally that had the TBI, it's from under the passanger dashboard under VIN E, Wires B(Pink/Blk) [the one on the right] and G(Pink/Blk) [the one on the left]. Help? I need to know what they do/ what they are for and where the are supposed to be connected?
Old Jun 7, 2010 | 07:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What are these 2 wires for????
Maybe something here will help - diagrams for almost all years, and shows wires from ECM:
http://www.austinthirdgen.org/index.php?pid=19
Old Jun 8, 2010 | 12:20 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
It would also be advantageous to get a datalogging type set up, and watch all your sensors. If any sensors are not reporting (MAF, ign, etc) then you've got a pretty good guess. BTW, a stuck open EGR will make the car run rough at idle (almost sounds like it has a lopey cam in it) but that wouldn't explain the stalling out very well.
Old Jun 8, 2010 | 12:46 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
cant get help without year and system ur runnin maf or speed density
Old Jun 8, 2010 | 03:12 PM
ntomsheck's Avatar
Car: 1989 GTA
Sounds like he's running MAF. His name is IROC-z 89, but I didn't think you could get an IROC with the LO3.
Old Jun 8, 2010 | 04:03 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Looks like they go to the following parts,
Air Select Valve
Canister Purge Valve
Air Diverter Valve
EGR Solenoid
Old Jun 9, 2010 | 09:13 AM
Pocket's Avatar
Car: 91 Trans Am
IROCs could be had with the LO3. Do a search of the history forum for more info
C207 pins B and G are the INJ1/2 fuses respectively. How you got it running short of these two wires is beyond me, and suggests more shenanigans under the hood
http://www.fbodyrescue.com/forum/vie....php?f=34&t=78
Old Mar 27, 2011 | 01:32 AM
Irocz_89's Avatar
Sry for the long post absence guys. I'm currently running a 1989 Iroc-Z Camaro 305 TPI. Trans is a 700r4. System is a MAF... Does that help?
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
