whats the box under the dash next to ecm?
Old Jun 13, 2010 | 07:31 PM
92orangestripes's Avatar
Car: 2000 expedition 5.4
Engine: .020 over 350, 9.5.1 comp,
Axle/Gears: 3.27 aussie 9bolt
its an aluminum case, with a yellow plug. when i turn key on, it buzzes, so i fanagled it out of the dash while it was on, cracked her open and yes, theres a little coil like doodad whapped in black shiny stuff, buzzing, when i press on it, it quiets, ????????????? WTF does this thing do? sorry for the language but my injectors wont pulse, or squirt so just wondering if this has something to do with it.
Old Jun 13, 2010 | 08:06 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: whats the box under the dash next to ecm?
Not sure but when you remove does the security light stay on? If so its VATS Box.
Old Jun 13, 2010 | 08:35 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Sounds like the VSS buffer box. It is mounted on the same plastic carrier as the ECM. Won't stop injector pulses.
The VATS is a plastic box the size of a deck of cards behind and above the radio. Very difficult to get to. It will prevent injector pulses and the fuel pump.
A picture would be handy.
Old Jun 13, 2010 | 08:50 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
sounds more like the airbag module by being next to the ecm and having yellow plug...like said b4 pic would help also what car is it.
Old Jun 13, 2010 | 09:36 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Nah, that box is under the center console.
Possibly a factory amplifier, thats where those were mounted, if so equipped.
Old Jun 13, 2010 | 09:43 PM
juanillox8's Avatar
Car: TOO MANY
nope my 92 has one by the ecm and another one on the center console
Old Jun 16, 2010 | 08:09 PM
sorry, i just put it back in, but i heard that if the ignition mod, under the cap goes bad this could happen, but my fuel pump kicks on, so i still aint sure what to do, its a 92 rs, and all this stuff was replaced 4-5 years ago, i drove it for a week, then the fuel pump went, it sat 4-5 years from there and finally i got it all back together, so now , no fuel injector pulse, fuel is gettin up there, what to do . . . . . . thanx for helpin me out anyway guys . but feel free to check out my pics anyway[hehe!]
Old Jun 18, 2010 | 11:15 AM
Pocket's Avatar
Car: 91 Trans Am
Sounds like the airbag module. Nothing else in the vicinity has an aluminum case and yellow plug. The buffer box is yellow or white plastic case
No injector pulse can be a number of things. Check the INJ1/2 fuses and that they connectors are getting 12v IGN on the pink side. If the 12v side is correct then the circuit to the ECM needs to be tested. TPIs are batch fired, but controlled by each bank, so testing one wire from each bank is sufficient. If the wiring checks out you've got a faulty ECM
Old Jun 19, 2010 | 11:24 PM
sacramento's Avatar
hey i am sorry but i need to ask you a question is it okay
Old Jun 19, 2010 | 11:32 PM
juanillox8's Avatar
Car: TOO MANY
who do u need to ask?
Casey Meyers
Mar 2, 2016 10:46 AM
snowflake
Oct 19, 2015 10:24 PM
355tpipickup
Aug 19, 2015 10:02 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
