Berlinetta blinker problem!
Old Jun 16, 2010 | 09:00 AM
algershick's Avatar
I'm typing this from the parking lot at work, trying to figure out what the problem is...
I haven't driven the car in 2 weeks, been on vacation. This morning on the way to work, blinkers worked fine. Now 3 hours later they don't at all. I can hear the relays in the light module tripping, and I tried to swap some relays too. The 4 ways DO work. I checked the fuse, its good too.
Any ideas, anyone with Berlinetta experience? John I know you're out there!
Old Jun 16, 2010 | 06:21 PM
algershick's Avatar
Re: Berlinetta blinker problem!
Troubleshot it at the auto parts store. It wasn't the flasher, so I kept fiddling with the relays in the light module. While the left and right turn signal relays were fine, the "flasher select" relay was the culprit. Problem solved!
Old Oct 6, 2010 | 08:21 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You need to be on my xmas list. My daughter's hazards wouldn't shut off this morning. Less than five minutes of 'search' and maybe fifteen minutes swapping relays around: "flasher select" relay. I'da spent all day otherwise. Thanks for posting back your solution, not everyone does.
Mike
Old Oct 6, 2010 | 11:48 AM
algershick's Avatar
Glad my faulty electronics helped you! I have numerous issues with the dash and light module since I've owned the car (1 year to the month!) but it has been a reliable daily driver to and from work. I've been able to figure most of it out myself, and I do have a few more issues to tackle.
I've thought about just ripping out the dash and wiring and putting a standard dash in, but I like the digital stuff too much to pull the trigger.
Old Oct 19, 2010 | 12:32 PM
naf's Avatar
naf
Argh. It wasn't the relay. Apparently in swapping the relay it powered down the circuit and turned it 'off'. Further playing shows that the relay only controls the speed of the 'blinking'. With the relay on 'turn signal' speed the hazards will blink double-time, as mine were doing it. So some electronic part was commanding hazard and the hazard select relay wasn't getting the signal-so it's probably not coming from the pod.
Old Nov 4, 2010 | 08:22 PM
Jt taylor sr's Avatar
I am having same problem ,no turn sigs ,but i have hazards I found only 1 frlasher under dash there is a place for another one only its just slots there is no wiring behind it ? what is the flasher select you are mentioning ?
Old Nov 4, 2010 | 08:52 PM
naf's Avatar
naf
The flasher select relay switches between two 'flasher' relays-turn signal and hazard. The hazards flash at half-speed (because both sides are flashing) and can be energized with ignition off. The turn signals flash double time (only one side flashing) and ignition must be on.
What is your particular problem. I've yet to resolve mine. It remains intermittent, goes away when the relay is pulled, and no other lights work when it occurs.
Old Feb 14, 2012 | 09:40 PM
Tstaggs's Avatar
On my berlinetta the turn signal contacts on the circut board broke in two, just a thought, i ended up desodering 2 that wherent nessesary to replace them. I have been having all kinds of trouble with my digital stuff. Maybe I'm just blind but I have found no relays, where might one find the relays on the berlinetta? Headlight relay in particular, when I start the car the headlights come on by themselves after a couple of seconds and try as I might they will not shut off, wich wouldn't be a problem but my dimmer is jacked up and blinkers stop after one or 2 blinks when they do. If the car isn't running everything works fine.
Old Feb 14, 2012 | 09:47 PM
algershick's Avatar
All of the lighting relays are located on the light module, which piggy backs on your ECM under the passenger side of the dash.
Old Feb 15, 2012 | 08:43 AM
Tstaggs's Avatar
I could here them clicking over there but all I saw was the ecu, that figures. Thank you much. If I think of anything useful for you I will let ya know, sry I'm not much help
Old Feb 15, 2012 | 02:28 PM
naf's Avatar
naf
I wound up replacing my light module with a known-good used one. No more problems.
Old Feb 15, 2012 | 07:21 PM
Tstaggs's Avatar
I may end up doing the same. My blinker/ headlight problem is puzzling me. My headlights won't stay off and the battery light comes on and when it does my blinkers stop working. Battery voltage is good and alternator is charging so as to why the battery light ?????? When the car is not running everything is ok. Something is screwy is all I know.... May I ask where you found a light module? I'm finding it hard to come across berlinetta parts.
Old Feb 15, 2012 | 08:38 PM
Tstaggs's Avatar
Ok well nevermind..... Apparently my alternator was putting out too much juice and the headlights were kicking on to comensate, I'm guessing. Unplugged the alternator and plugged it back in and all is good, voltage back to normal. Ohh this damn berlinetta....
Old Feb 16, 2012 | 06:34 AM
naf's Avatar
naf
If you need the parts, John in RI is usually a good source.
And yes, voltage issues can cause trouble with these old style circuit boards.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
