starter enable switch
Old Jun 18, 2010 | 02:34 PM
busterbrown's Avatar
Car: 1992 formula firebird
Engine: 355 TPI
Transmission: currently a T-5, eventually a T-56
Axle/Gears: 3:42
Hey y'all
can anyone tell me where the starter enable switch is located on a 92 firebird? Ive been told that is behind the kick panel encased in goo, but i have yet to find this mysterious piece of electronic crap. I would like to bypass it, but cant do that till it is located.
Old Jun 18, 2010 | 02:51 PM
RyanEricW's Avatar
Re: starter enable switch
Do you mean relay?
Old Jun 18, 2010 | 02:55 PM
Engine: 355 TPI
Axle/Gears: 3:42
which ever is attached to the key that prevents the vehicle from starting. I can start my car with a remote switch that is attached directly to the starter, but not with the key itself.
Old Jun 18, 2010 | 03:22 PM
Engine: 355 TPI
Axle/Gears: 3:42
yes relay. do you know where it is?
Old Jun 18, 2010 | 03:57 PM
Drew's Avatar
You were told right... The 'goo' is a piece of sound deadener that covers the opening in the kick panel. You might have to peel it back to see the relay, just follow the wires.
Old Jun 18, 2010 | 04:00 PM
Drew's Avatar
By the way, if you're talking about the VATS passkey decoder module, the box is up behind the passengers side of the dash hull.
Old Jun 18, 2010 | 08:56 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
He said he could start the car by jumping the starter, so the VATS module probably is fine, just the relay went out.
Old Jun 18, 2010 | 09:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you can start your car and it runs, then the VATS is not the issue - a bad pellet in the key or a bad VATS system would not allow the car to run - VATS cuts off the injectors at the ECM, so if the car runs after starting, VATS is doing it's job.
So, your issue is with the starting circuit. Either the starter enable relay, or the neutral safety switch (NSS). I wouldn't "bypass" this relay - it would be quite involved to do so - it's just a relay, they usually last years and years - replacement would be much easier.
If replacing the relay doesn't help, then you have a NSS issue, try replacing it next.
Old Jun 19, 2010 | 05:18 PM
Engine: 355 TPI
Axle/Gears: 3:42
I found the relay on top of the fuse block. I ground the black wire and the car will start through the key now. There was no square of black goo behind my kick panal. I did get the problem fixed though. Thanks for all of your help, I appreciate it.
Old Jan 2, 2011 | 08:33 AM
cspawnkillu's Avatar
i pulled the goo back and didnot see any thing in it but under my dash looks like what u are talking about,
Old Jan 5, 2011 | 10:22 AM
can the starter relay be under the dash i didnot see anything in the goo
Old Jan 8, 2011 | 12:17 AM
travis401's Avatar
Car: 91 Camaro RS
its possible it may have been moved by someone.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
