1992 wiring issue
Old Aug 5, 2010 | 12:43 AM
sethorama's Avatar
1992 wiring issue
i bought the car dropped a carb 350 in
this car orginally was a v6fi
the guy i bought it from cut almost all of the wires
so i need instructions on how to wire up my
starter wiring
alternator wiring
distributor as well if needed
battery 12v wire and ground and placement where to put them
any help will be appreciated
thanks
EDIT:
And how to wire up all my gauges
tranny is a th350
thanks again
Old Aug 5, 2010 | 07:06 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 1992 wiring issue
Read this
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
And try again
Old Aug 5, 2010 | 12:38 PM
sethorama's Avatar
Originally Posted by Pocket
ive looked through that
I said again my wires are hacked up
I need directions to rig all mine up
Old Aug 5, 2010 | 04:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Here's diags for almost all 3rd gens - you can trace wire colors from the diags and rewire the basics you need from there.
http://www.austinthirdgen.org/index.php?pid=19
Old Aug 5, 2010 | 04:59 PM
Car: 1992 RS
Engine: Carbed 350
Do you have at least the majors? Like battery cables, alternator, etc.? What about lights, electric rad fan, etc. It would help to know what you currently have wired, and what's working and what's not specifically.
Old Aug 5, 2010 | 11:15 PM
sethorama's Avatar
it has bassically the whole passanger side of wiring
but i thought they was useless since im going carb
lgihts and all that is there
battery + is there but i dont think it is hooked up anywhere cuz i put a new ground on the frame to install my battery and i turned the key and got nothing
i dont have a eletric fan atm
im gonna order a fan off of summit payday next week
so i guess what i am needing is how to wire up my + side of my battery , my alt , starter , i just want to get it started for now and than i can worry about my gauges after
Old Aug 6, 2010 | 12:11 AM
Car: 1992 RS
Engine: Carbed 350
Wow - the PO really did a number on the wiring then - you are right, the pass side wiring is not needed, but the driver side is. Why so many idiot want to hack up wiring is beyond me - never cut the wires out, just tuck aside what you don't need!
If it were me, assuming you still have the bulkhead connector on the firewall under the brake booster, I'd go to a JY and get the driver side wiring harness of any 3rd gen I could find, and plug it up, rather than trying to rewire everything from scratch.
Good luck!
Old Aug 6, 2010 | 12:45 AM
sethorama's Avatar
Good luck!
any other suggestions or easy to read diagrams lol
that one i looked at looked pretty complicated
Vintageracer
Jan 10, 2020 05:33 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
