Forgot how to wire alternator
Old Aug 6, 2010 | 11:01 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
So what wires go to the alternator? The red plastic connector on the back and a black wire attached to one of the rear bolts on the alternator right?
I was installing headers and had the alternator removed for like a month and now I can't remember how many wires were connected to it. It seems like I'm missing something.
84 TA, 305 LG4
Old Aug 9, 2010 | 12:11 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wire Mire
The heavier red wire goes to the positive stud, and should have power at all times.
The thinner
red wire goes to terminal S (the sensing circuit) and should have power at all times.
The
brown wire goes to terminal T (the turn-on input) and should have power when the key is in the RUN position.
Not sure about that black wire.
Might be a PO addition.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
