Electronic shifter??
Old Aug 8, 2010 | 09:01 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
hey i have a 83 camaro with a 305, 700r4 tranny automatic. on the shifter it has 3 wires going to the side of it. anyone know what these wires are? and how i can get around them to put a new shifter in?
Old Aug 8, 2010 | 09:42 AM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
Re: Electronic shifter??
Should be a nuetral saftey switch. There may be a provision for a light as well?
Old Aug 8, 2010 | 11:08 AM
vinny83's Avatar
idk, i heard somewhere it may be the lockout for the tranny, and the one wire that lights up the reverse lights when im in reverse..would it hurt the tranny if i just unhooked these and hooked up a switch for the reverse lights?
Old Aug 8, 2010 | 11:15 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Only 3 wires?
The transmission doesn't care about the shifter wiring in any case.
Old Aug 8, 2010 | 11:25 AM
vinny83's Avatar
yea, only 3. they hook up to a roundish plastic piece on the side of the shifter..
Old Aug 8, 2010 | 12:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you unplug it, the car won't start unless you tie the two larger wires together - the starter wiring runs through the neutral safety switch and won't allow the car to start unless you are in Park or Neutral.
Old Aug 8, 2010 | 02:19 PM
vinny83's Avatar
u sure? i dont wanna mess **** up lol. i have a z-gate b&m shifter i wanna put in and take out that longgg center console.
Old Aug 8, 2010 | 05:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, there are 2 large wires, probably purple and yellow, they are the neutral safty, they have to be together for the car to start. the other wire im unsure of, could be for backup lights. the later model cars have 6? wires on the shifter.
Old Aug 9, 2010 | 10:33 AM
vinny83's Avatar
yea, u got the purple and yellow right..and i unplugged the connector, there areee 6 wires, 2 big, 4 small. anyone know what the 4 small ones are? and if i can just unplug them?
Old Aug 9, 2010 | 10:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The others are for the reverse lights and a P-N signal for the ECM.
Old Aug 9, 2010 | 11:09 AM
Car: 1992 RS
Engine: Carbed 350
One of the 4 will enables the rear hatch switch so you can't pop the rear hatch while driving.
Old Aug 9, 2010 | 11:14 AM
Car: 1992 RS
Engine: Carbed 350
Here's wiring diags that should help you:
http://www.austinthirdgen.org/index.php?pid=19
Old Aug 9, 2010 | 12:36 PM
vinny83's Avatar
lol, this is my first camaro and im still learning. so if i tie the 2 larger wires together, and hook up something for the reverse lights, i can unhook the others, and not worry about them?
Old Aug 9, 2010 | 12:52 PM
Car: 1992 RS
Engine: Carbed 350
Doesn't the new shifter have provisions for the wiring? Maybe you bought a used part that is missing something? I'd check with the shifter manufacturer.
If you tie the two large wires together, it will bypass the neutral safety switch for the starting circuit, but then the car can be started in any gear (a safety issue since it could start in drive and run over someone, hit a parked car, etc.)
Old Aug 9, 2010 | 06:44 PM
vinny83's Avatar
lol nope. and its not missing anything. its not even meant for this transmission lol. its a b&m z-gate shifter..not the megashifter like y'all might have. only paid 30 bucks for it, so im tryin to make it work..looks awesome.
Old Aug 15, 2010 | 10:52 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
• Large purple and yellow wires are the Neutral Safety Switch wires.
• Small blue and green wires are for the reverse lights.
• Small orange and black wires are the torque converter lock-up wires when the engine is idling. This changes the idle RPM. You can leave these disconnected if you want.
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
