Few more issues
Old Aug 21, 2010 | 08:55 PM
rabidcanadian's Avatar
Few more issues
I can't seem to find an answer to these issues and if they may all be related or not.
Horn not working
Trunk release not working, but pull down does, brake light works when button pushed
power antenna not working, new antenna assembly that has been checked to make sure it works
turn signals work but real slow
power windows work, but power locks do not
no interior lights
dash lights up with lights on but dimmer does not work
All this plus the check engine light not working
Fuses all good, can't think of anything else at the moment
Can anyone point me in the right direction to getting these issues solved?
Old Aug 25, 2010 | 02:05 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Power This Hour
The horn, hatch release, power locks, and interior lights are powered VIA the ACC fuse.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe both sides of the ACC fuse.
Is there power both sides?
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Aug 28, 2010 | 04:03 PM
Re: No Power This Hour
Getting things sorted out here...
Horn, locks, interior lights, ect all working now. Turned out to be a broken tab in the fuse box.
As for the trunk release.. it works when I ground the wires on the back of the switch, so might be a ground issue or maybe just the switch has gone bad.
Now if only I can find out why the check engine light doesn;t work.
Old Aug 30, 2010 | 12:09 PM
NINÅ's Avatar
Transmission: 765R4
Check The Checker
With the ignition OFF disconnect the ECM.
Using a fused jumper
(1 amp is good) ground pin A5 of the connector (not the ECM).
Now, turn the key to the RUN position.
Does the
Service Engine Soon light come on now?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
