temp guage not moving
Old Nov 29, 2010 | 09:34 PM
thegoochking's Avatar
my temp guage doesnt move at all. When i turn the key it just sits there so i never know what temp my engine is running at. What could be the prob and how do i fix it.
Old Nov 29, 2010 | 09:47 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: temp guage not moving
sounds like the temp sending unit on the motor there are 2 but i think it is the one on the front of the motor near the top radiator hose inlet but i may be mixed up
Old Nov 29, 2010 | 09:49 PM
is that the thing that plugs in right above the iac?
Old Nov 29, 2010 | 09:50 PM
talover111's Avatar
it should be right on the intake next to the top hose inlet
Old Nov 29, 2010 | 09:55 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There is only one sending unit, it's in the drivers side head between exhaust ports 1 & 3. The one for the ECM is a sensor. Tha coolant temp sensor is located under the throttle body, in the front of the manifold on a TPI.
Is the gauge sweeping during crank ? (full hot)
Old Nov 29, 2010 | 09:57 PM
No the guage doesnt move at all every
Old Nov 29, 2010 | 10:06 PM
deadbird's Avatar
Engine: TPI 305/ v6
It may have moved on to a better place then.
When you start the motor (crank), the gauge should ground, through the ignition switch, causing it to shoot up to full temp.
With the key on, ground the single green sender wire to anything ('clean' metal). If you still get nothing, full temp, then the gauge may be finished. A new sending unit won't fix the problem.
Old Jan 31, 2011 | 09:51 PM
Just came back to this thread, suddenly after resetting my ecm my guage now spikes when i crank the engine but it only goes to 100 and never moves up from there. Where is the temp sending unit and how will i know if its no good or even there?
Old Jan 31, 2011 | 10:17 PM
CamaroIROC88350's Avatar
Try hitting your dashboard in the area above your temp gauge a couple of good times. When my temp gauge stopped moving 2 years ago I thought it was the sending unit's fault. Turns out hitting the dashboard fixed it!
Old Jan 31, 2011 | 10:18 PM
lol i think ive tried that didnt want to hit it to hard since i still have a crack free dashboard lol. But it sucks never knowing if im running hot or not.
Old Jan 31, 2011 | 11:07 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Do you mean smack it with the Harley tool AKA ball peen hammer???
Old Jan 31, 2011 | 11:16 PM
Nah, just one of your hands will do, lol.
Old Feb 4, 2011 | 10:24 AM
confucius101's Avatar
same if not similar here
when i start my car marker goes straight to full then right back down to nothing lol
Old Feb 4, 2011 | 10:40 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
With the engine OFF, but key in the RUN position, at the engine jump the temperature sender wire to ground.
If jumping causes the gage to peg replace the sensor.
Happy Racing!
Maybe I Should Have The Guys Put A Door In The Bottom For Any Roll-Overs In 2011
Old Feb 22, 2011 | 09:33 PM
Skribb's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6 mpfi .40 over
Transmission: 700R4 stage 2 shift kit
Axle/Gears: 3.42 factory
i have a similar issue with my 89 RS 2.8 except mine is past hot and never moves down ive hit the dash with no change it dropped once and worked fine until i shut the car off when i started it again same thing way past the coolant temp symbol on the gauge and never comes down being winter and knowing signs of overheating i havent worried much but come spring would be nice to know what its issue is ive replaced the sensor for the gauge and did nothing
Old Feb 23, 2011 | 08:57 AM
NINÅ's Avatar
Transmission: 765R4
Vanna, He Needs To Buy A Few Periods.
There might be a short in the sender line.
With the engine OFF and key in the OFF position, use an ohmmeter to measure the resistance from the temp sender to ground.
It’s a
dark green wire.
The temperature gage sender is located on the left, below the valve cover, on most VINS.
What is the resistance?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jun 29, 2012 | 12:33 PM
tstorrie's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Transmission: L700 Automatic
Axle/Gears: 3:73
Hello, the temp gauge wire on my car is missing. I,m trying to reconnect it, but i cannot find where to reattach it. I found a green wire going to the horn, a green wire that runs through a relay on the fire wall, it has a brown/white wire coming from it which has been cut, and finally I have a light green wire which runs down the firewall towards the transmission. The gauge in the car is pegged to the top. I really didn't want to have to unhook the bulk head to find the F5 pin. any suggestions? Thanks in advance.
Old Jul 2, 2012 | 07:34 AM
NINÅ's Avatar
Transmission: 765R4
Temp-orary Insanity
The gage pegged is consistent with the dark green wire being shorted to ground.
If you can’t handle it at the firewall connector you can disconnect the present
dark green wire from the dash, then run a new one to the sender, by drilling a hole, using a grommet, and passing thru the wire.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Jul 3, 2012 | 09:12 PM
tstorrie's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Axle/Gears: 3:73
Thanks for the advice, I'll try the instrument cluster this weekend.
junior419
Apr 7, 2025 11:35 AM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
andy74
Sep 3, 2015 08:41 AM
