wiper motor issue, HELP
Car: 1983 camaro z28
Engine: 305 HO.
Transmission: A5- 5 speed
Axle/Gears: 3.73 gears
i bought a 83 z28 and it came with a new wiper motor, i plugged the new one in and didnt do jack. What should i do, i know the motor is good,
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Remove Windshield To Prevent Wet Visibility Problem
See if your wiper switch is getting voltage in.
If it isnt getting voltage in, trace it back to the fuse.
If it is getting voltage in, see if it puts out voltage when you cycle the switch.
If it puts out voltage when you cycle it see if its making it to the wiper motor.
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
Happy Racing!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Remove Windshield To Prevent Wet Visibility Problem
The following is from an 85, but may be helpful:
https://www.thirdgen.org/forums/elec...ml#post4350355
JamesC
JamesC
Car: 1985 Camaro Z-28 T-top
Engine: 4bbl 305
Re: wiper motor issue, HELP
I know this doesn't deal with the problem from the original post but while we are on the subject of wiper motors, the washer pump is built in to the pump is it not? My wipers work but when I try to wash the windshield all I get is the wipers. It sounds like it wants to but I get nothing. Could the lines just be clogged? The car is 25 years old after all and the previous owner wasn't driving it much it just sat in his garage most of the time
Car: 84 Trans Am
Engine: Turbo 301
Car: 85 Camaro Z28
Engine: 5.7 TPI
did the new motor come with the electronic board inside of it? I had this issue a while back and none of the replacement motors included the circuit board.
Engine: 4bbl 305
Yes of course there is fluid in the tank, that was the first thing I checked. It is dark outside now but I will try that tomorrow and see if I get anywhere. Thanks
