VACUUM GAUGE INSTALLATION
Old Dec 19, 2010 | 12:35 PM
fast z28's Avatar
Car: 1983 camaro z28
Engine: 305 HO.
Transmission: A5- 5 speed
Axle/Gears: 3.73 gears
hello, i need some help installing a vacuum gauge in my 83 z28.
My problem is, i cant find the 12v dash lights, and the 12v ignition switch under the dash, is it a fuse or what?
http://www.princessauto.com/componen...438_manual.pdf
Old Dec 19, 2010 | 05:48 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: VACUUM GAUGE INSTALLATION
You can get the 12 volt dash light wire at the back of the headlight switch. I think its a brown wire. The 12 volt ignition wire should be a larger pink wire coming out of the ignition switch on top of the steering column under the dash.
Old Dec 20, 2010 | 11:09 AM
fast z28's Avatar
Engine: 305 HO.
I hooked it up to a couple fuses yesterday, i have it wired so when you pull the light switch all my tachs light up. cons?
Old Dec 20, 2010 | 11:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's the way it's supposed to work.
Old Dec 20, 2010 | 11:20 AM
fast z28's Avatar
Engine: 305 HO.
perfect, do you have a visual of my fuse box and what fuse does what. Link? mine is faded, its for a 83 z28.
Old Dec 20, 2010 | 10:01 PM
fast z28's Avatar
Engine: 305 HO.
what is the reg vacuum for idle?
Old Dec 20, 2010 | 10:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Depends on your cam. Probably about 18 inHg or so stock.
Old Dec 21, 2010 | 11:32 AM
fast z28's Avatar
Engine: 305 HO.
i have a air fuel mixture gauge also, it comes with a sensor . where does the sensor mount to? intake manifold?
Old Dec 21, 2010 | 11:33 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
An O2 sensor bung in the exhaust
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
