did the bypass still won,t crank
Old Dec 23, 2010 | 04:53 PM
cspawnkillu's Avatar
i did the resistor in the white wires the right way,still no cranking i did hear the fuel pump now come on. i heared the security light needs to be flashing my just stayes on. if anyboby has had this please let me know what to look for.
Old Dec 23, 2010 | 08:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: did the bypass still won,t crank
Fuel pump not related to VATS
Have you hotwired your starter to confirm it actually works?
Bypassed the starter enable relay to see if it is faulty?
Checked the clutch safety or P/N switch to see if it is working?
Confirmed you have 12V on the starter circuit out of Ign switch when in start position?
If you have faults with any of the above ,your engine won't crank regardless of what you have done to the
VATS system ( bypassed )
Old Dec 25, 2010 | 03:08 PM
i did not check the starter how do you do that without taking it off. [hotwiring it] and what is the p/n switch, and i will look for the starter enable relay on my 92 firebird, sorry i don't know alot about this stuff.
Old Dec 25, 2010 | 05:18 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Put car out of gear/ park brake on ; connect a wire to starter solenoid ( small purple wire at starter ) and touch on the batt +.
If starter is working it should crank engine.
If it doesn't then your starter has a fault ( not a wiring to starter problem )
The switch on the auto shifter that stops you starting engine in gear ( or on the clutch pedal for stick cars )
See
https://www.thirdgen.org/forums/post...079-post3.html
Typical GM starter circuit
As you can see ,the power has to go from the Ign switch to starter.If any part not working then engine won't crank
Old Dec 25, 2010 | 05:22 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
i will look for the starter enable relay.
https://www.thirdgen.org/forums/post...038-post5.html
Old Jan 2, 2011 | 08:36 AM
i pulled the goo back but nothing there but under my dash looks like what u are talking about.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
Formula_88AE
Sep 3, 2015 01:47 PM
