Dimmer Switch?
Old Jan 18, 2011 | 03:41 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Dimmer Switch?
I'm trying to look for a new dimmer switch for my 1989 camaro. mines crapping out; so i'm looking to get a new one. I got this.. never seen these in our cars...
http://www.autopartswarehouse.com/de...QACD1920D.html
Old Jan 18, 2011 | 04:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Dimmer Switch?
The link is showing an error.
JamesC
Old Jan 18, 2011 | 04:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Dimmer Switch?
The actual switch itself is located on the bottom of the steering column, above the brake pedal. The wiper arm at the steering wheel simply moves a rod in/out of the actual switch at the bottom of the column. The actual switch looks like:
http://www.autozone.com/autozone/par...mString=search
Yours might just need adjusted - there are two small screws that hold it in place, loosen those slightly and push the switch up/down the column just a very small tad and retry. If you have a tilt wheel, set the tilt where you normally drive - it's virtually impossible to get the switch adjusted where it functions at all stages of tilt.
You can move the wiper lever while under the column and see the rod moving.
Hope that helps!
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
