Blinkers not working
Old Jan 19, 2011 | 06:37 PM
digitaljo3y's Avatar
Car: 1999 camaro
Engine: v6
I'm having a real problem with my blinkers on my 1999 chevy camaro. My hazard lights will blink, and the the blinkers will come on when i click the bar up or down but they wont blink. Any ideas?
Old Jan 19, 2011 | 07:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Blinkers not working
Blown bulb
Old Jan 19, 2011 | 07:56 PM
Car: 1999 camaro
Engine: v6
oh, believe me if it would've been that easy i would've had it fixed a long time ago.
Old Jan 19, 2011 | 08:09 PM
Car: 1992 RS
Engine: Carbed 350
Did you check all the yellow bulbs? In the front there are the turn signals (which are also the daylight running lights), as well as the side markers.
There might also be a different flasher module for the turn signals as opposed to the emergency flashers.
But it really sounds like a blown bulb to me.
Might try asking on a 4th gen F-body site - TGO is a 3rd gen F-body site. I happen to have a 1997 Z28 so I have a dangerous amount of 4th gen knowledge, but to really get to the heart of the matter you'd be best to check on a 4th gen board.
Old Jan 19, 2011 | 08:13 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i am not sure about a 1999 camaro . this is a 3rd gen. forum not a 4th gen . but , i believe there are 2 different flashers . 1 for turn , 1 for emer. flashers . i would check the flasher unit . good luck .
Old Jan 19, 2011 | 08:36 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
In addition to my 88, I also own a 99 as well. Have you checked the rear turn signals? If the rear on mine goes out the front won't flash, they just light up and stay on with the blinker activated. Usually when this happens the turn signal indicator on the side blown will stay lit instead of flashing.
Old Jan 19, 2011 | 08:37 PM
86ta-adf's Avatar
Car: 86 Trans Am
A blown bulb would usually just make the indicator flash quicker. Check the flasher they are only a couple bucks.
Old Jan 19, 2011 | 11:42 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Remove your radio and behind it check the daytime running lamp module when they go bad you have no blinkers,if its not the bulbs.
Old Jan 20, 2011 | 06:43 PM
Car: 1999 camaro
Engine: v6
ok, thanks guys
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
