86 Trans Am Headlights Not Flipping Up..... PLEASE HELP!!!!!
Old Jan 20, 2011 | 12:27 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
ok got this car about 2 years ago and since ive had it the headlights have never came up by the switch i would always have to pop the hood and manually twist them up.... Well this was not a daily driver so i never really thought twice about it, but my other car just bit the dust so my trans am has to be my daily driver for a few months until i can get another car, now im trying to nip this annoying problem in the butt...... I tried jumping them straight from the battery when i did the drivers side the light just came up but wouldnt go back down with the swith i had to twist it back down and when i jumped the passengers side the **** that you twist to bring light up just started to twist really fast but the light never came up..... Does this sound like my headlight motors are bad?? and if not what are some suggestions of stuff to look for first???
Old Jan 20, 2011 | 01:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Door Heavy
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the headlight module terminal 1A yellow wire, then 1C brown wire, to see if they get power when you turn the headlights on.
The headlight module is a rectangular unit about 3" x 4" mounted in a bracket on the left side of the firewall.
Happy Racing!
I’ve NEVER Hit The Wall! - The Safer Barrier Prevented It
Old Jan 20, 2011 | 01:22 PM
dredre08's Avatar
Re: Light Door Heavy
and if they are not getting power what should i assume.
Old Jan 20, 2011 | 01:47 PM
Stephen's Avatar
Car: 87 GTA
Re: 86 Trans Am Headlights Not Flipping Up..... PLEASE HELP!!!!!
Here is the Headlight Control Module. If it dies? The lights come on, but not up.
You can open it up, look inside & see if it has gotten dirty inside, broken traces....anything wrong inside.
Old Jan 20, 2011 | 02:55 PM
dredre08's Avatar
Is that under the hood????......, and I also noticed that my high beams don't go off they just stay on, could that be tied in with the problem with the headlights??
Old Jan 20, 2011 | 03:04 PM
Stephen's Avatar
Car: 87 GTA
Yes. That is on the firewall, just to the right of the engine. The mount stays in place & the Module itself slides out. To the right, IIRC.
I *think* it could have something to do with your Highs staying on too. I'd look inside it (4 screws hold the back plate on) & look.
Old Jan 22, 2011 | 08:54 AM
dredre08's Avatar
Hey steven, do they look the same from all the years thirdgen, because I looked but dont really see what you posted in the pic here is what I see:
Attached Thumbnails 86 Trans Am Headlights Not Flipping Up..... PLEASE HELP!!!!!-imag0152.jpg   86 Trans Am Headlights Not Flipping Up..... PLEASE HELP!!!!!-imag0153.jpg
Old Jan 22, 2011 | 10:10 AM
Stephen's Avatar
Car: 87 GTA
I have those 3 relays too. Look about 6" to the left of them.
It is basically a dual-relay for the headlights. I know the early 'birds, 82-?, are different. If 87 was the first year for the single "dual-relay" module, you'll hafta find a 82-86 'bird owner to find out the wiring/setup from.
Old Jan 22, 2011 | 10:15 AM
Stephen's Avatar
Car: 87 GTA
<double post>
Old Jan 22, 2011 | 10:23 AM
dredre08's Avatar
Mine is a 86, I'm actually at a junkyard while I'm writing this, and its a 1990 trans am with the one just like in the pic u posted could I just take that off and put it on my 86 and what all do I need from this car
Old Jan 22, 2011 | 10:56 AM
Stephen's Avatar
Car: 87 GTA
'90will be like my 87, but as mentioned above.....Not sure when they switched the wiring from 1 relay for both headlights, to the dual, like mine.
The dual was created so that even if 1 went out, the car would still have 1 useable headlight.
Old Jan 25, 2011 | 11:55 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The 86 TA relays for the headlight actuators are on the front fenders one is on the LH side in front of the radiator overflow canister,the other one is on the RH side in front of the windshield washer canister.
Looking down from the front of the car.
Hope that helps you out!
Old Jan 26, 2011 | 10:07 PM
dredre08's Avatar
Ok guys I found the relays, now were should i go from there?? How do I know if they are good or bad and how do I test them???
Old Jan 26, 2011 | 11:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
I really think you have a fuse problem,check for a bad fuse,and if it is good,check the fusible links D,E and G,they are located at the front light harness near the LH radiator shroud.check to see if any of them are broken first.They look like a thin wire going into a fatter wire,in between them is a fat piece of insulation.
It's not likely that two relays go at the same time.
Old Jan 28, 2011 | 04:05 PM
dredre08's Avatar
So exactly were would the fuse for my headlights be at???
Old Jan 28, 2011 | 04:27 PM
Stephen's Avatar
Car: 87 GTA
Same place as all the other fuses.
Old Jan 28, 2011 | 04:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
Are we talking head lights or the doors
Old Jan 28, 2011 | 07:14 PM
dredre08's Avatar
We are talking headlights, I'm looking at my chilton book and it doesn't show a fuse on the fuse block that's for the headlights
Old Jan 28, 2011 | 07:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
The headlight switch has a built in circuit breaker,does your lights come on and your doors stay closed.
Old Jan 28, 2011 | 08:10 PM
dredre08's Avatar
Yea they come on but they don't come up
Old Jan 28, 2011 | 08:16 PM
mantaguy's Avatar
Engine: 5.0 EFI
OK you have a headlight door problem.
Old Jan 28, 2011 | 08:22 PM
mantaguy's Avatar
Engine: 5.0 EFI
Their is a test to do for that,but you have to locate the Isolation relay,the manual says it is RH front of engine compartment near the cruise control servo,but I can't find mine either.so maybe someone will tell us where it is.I can't see it's to dark and cold out.
Old Jan 28, 2011 | 08:35 PM
dredre08's Avatar
Darn!!!!, I hope some one that can chime in but what is the test you do to the isolation relay?
Old Jan 28, 2011 | 09:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
It's pretty simple,use a tester,with the light switch off ground the yellow wire it should not light,turn the switch on and it should be hot,then ground the white wire with the switch off and it should be hot,turn the switch on and it should be hot,then you ground the dk.blue&white with the switch off and it should be hot,then you ground the pink with the switch off and it's not hot,then turn the switch on and it should be hot,then you ground the dk.blue with the switch off and it should be hot,then you ground the black with the switch off and it's not hot then turn the switch on and it's not hot.
If the voltage at the yellow is not correct check the light switch.
If the voltage is not present at the white on off check the tail fuse and light switch.
If voltage is present at the black it's faulty ground.
If other voltages are not correct replace the Isolation Relay
1992 Trans Am
May 10, 2023 07:19 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
The_Phoenix
Feb 4, 2016 07:10 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
